What has left me Gobsmacked......
For means of comparison with Seamus' A3112...
Here are a few pictures of the next model up, in the pecking order.
Mathew's A3114 Selectamatic 1100...
and from the back, with the indicator arm clearly apparrent. Always worries me that this indicator arrangement looks a bit fragile...[this post was last edited: 6/2/2010-11:39]
For keyplate reader, instead there is effectively a permanent cylindrical keyplate with a wide variety of programme options....
Also in the 'Smoother' Range were:
A3108 Electronic 800 (square door)
A3166 Automatic 610 (round door)
A3170 Automatic 800 (round door) - anyone got a picture of this machine at all? Very evasive machine with no evidence, other than a sheet of paper, to show that it existed!
D6074 Dryer De Luxe.
An all encompassing series of machines.
Paul
Well done!
It is good to see those machines alive and kicking.
Mum and Gran each had the A3110. I remember wondering about the Keymatic and Selectamatic, as I studied the monochrome Installation Instruction sheet.
Nice to see them in the flesh.
New door gasket.....
The old one was starting to craze/perish and had a slight dribble on the door glass seal. Hoover no longer make the original design for this machine so I fitted the post 1985 version. The main difference is its ribbed on the inside and the folds are smaller so you dont get as large a "trough" of water to mop out after use.
in use
Hello Seamus
Does that mean we are going to see your Keymatic installed as your daily driver in the kitchen :-)
This would be brilliant, like Mat uses his 3060 as a daily driver aswell..........
Gary
Hoover Washer
Hi Seamus,
What a fantastic find and machine.
Hope you can post a video soon.
Regards
Paul
Daily Driver??
Hey Gary
Once its bearing/slight rust issues are sorted then it will indeed be sharing duties with the Insight :).
The A3308 will rotate position with it once the suspension is attended to as well ;).
Fortunatly because of shared pipes im unable to be metered :D
Paul.....
Once its installed in position videos will be attended to :).
Seamus
