What is a Cycle?
RAX5133A
I am positive these models, at least the ones I've seen with the Fabricare label on the dial, are single speed. Pics of the same washer from a used appliance store advertising online give a model number of RAX5133A. The publicly available tech sheet for RAX5133 shows a single speed motor depicted. The cycle on the timer sequence chart is called "short"
Normal is labelled at 6 minutes in, I think Whirlpool knows the agitation is rough on high agitation.
https://shortiesappliances.com/products/roper-washer-6975
The machine of Chet's photo in Reply 21 is not the same model as Dan's photo in Reply 19.  Dan's is a better-featured model, references Knits-Delicates, not Fabricare, and may be a 2-speeder.
Yes dad ours was a two speed. I think he’s right, they made a more basic Super capacity model which was a single speed given his evidence. I figured fabric care was another name for delicates they used. Ours had a fabric softener dispenser too and this one Chet shows has a cap, and every model just like mine I’ve seen has a dispenser so I’m very sure that ours was the top of the line Roper you could get and only the top of the line models provided softener dispensers. I think it was the same for the standard capacity Ropers at the time, the basic ones were a single speed and the higher end ones were two speed with a softener cup. We can only make educated guesses from what we’ve seen given I cannot find the damn manual for ours anymore even though we kept it, I’ll have to keep looking but I can pull it up online and confirm this if your interested Chet.
No that photo is of the very first roper washer design they made you just put up. A few years later they redid the control panel and pushed the knobs closer together and the timer farther to the right. The first photo I posted earlier of it sitting next to the dryer was our machine that was taken in the early 2000s by my grandma probably. I’ll attach pics of an identical model to ours I just saw on marketplace recently. Completely identical.
