This is a Kitchen Aid electric dryer model KEYS850GQ0. This is a basic Whirlpool-made dryer that has been produced for years and Whirlpool still make this same basic model under various brands.
In the last week the dryer won’t stop on the auto dry cycle. It will just run after the clothes are dry and keep going. It seems to work normally on timed settings where you just set a certain number of minutes.
Read below and feel free to offer any suggestions or poke holes in my logic. I’m a competent DIY’er with plenty of tools, so I’m not afraid to tear into this if it’s a cheap fix. So far, I’ve disassembled and cleaned a whole bunch of things. We will see if that helps.
I may just replace the dryer with a new one if it’s not easily fixable. I bought this used for $125 in 2008, so it has served me well and I’ve definitely gotten my money’s worth. The only repair it needed over those years was a faulty thermal fuse that I diagnosed and fixed myself.
I’ve done some research and I think this auto dry function works:
-The wet clothes hit the sensor in the tub and make a complete circuit. When they’re dry, the circuit is broken and that starts a final countdown on the timer.
-Basically, when the clothes are wet they provide a ground path and when they’re dry the circuit it broken and that allows the timer to advance and eventually end the cycle.
Here’s what I’ve checked:
-I took out the moisture sensor and it appears fine. This is a pretty simple device. The way it operates, the only malfunction I can think of is if there’s a crack or something that allows the sensor to constantly ground out and not trip the timer to end the cycle when the clothes are dry.
-The circuit board looks OK. one side is a little brown with age, but nothing is obviously burned or blown up. I don’t know of any definitive ways to test it.
-No wires are obviously cracked or broken.
Here are my suspicions:
-Either the circuit board or the timer have failed.
-If the circuit board failed it wouldn’t tell the timer to move towards the end cycle when the moisture sensor detects the clothes are dry. But, I have no way to check this and I don’t know if the dryer would run at all if the circuit board failed.
-If the timer failed, perhaps it wouldn’t advance to the end of the cycle when the moisture sensor indicates the clothes are dry.
