The current whirlpool top load washers VMW machine machines
Are better than ever the first five years of these machines were a lot of problems. They’re not having problems with them anymore, except an extreme use situations.
Whirlpool’s worst top loading washers were the last three years of the direct drives.And the first 5 years of the VMW machines Everything seemed to go wrong with those prematurely.
Maytag lover 68 is just getting batches of machines in from who knows where he has no idea how they were used. They could’ve been in nursing homes and everything else in between.
We have quite an advantage because we normally work for the customer with the machine and we often see what they’re doing wrong to cause these early failures, anytime you have a bearing failure you have a seal failure and something made the seal go bad we can often see what the customer is doing wrong usually it’s far too little detergent and cheap detergent, etc.
A modern top load washer with strut failures within 10 years has had a hell of a lot of use thousands of loads for that type of failure.
I have seen zero sign that whirlpool quality has deteriorated. In more than a decade I have not seen a new whirlpool Appliance out of the box that didn’t work perfectly, I just got done installing new appliances today and as usual everything works perfectly.
Just got done replacing a 20 year-old duet dryer with a new whirlpool dryer this afternoon. She’s already had the whirlpool front load washer since 2019 in a family of six with zero problems. The plastic door is holding up beautifully. It’s really a nice design if you look at it, it has a much better shape than the glass doors on front load washers.
John L
