What is the most reliable top load washing machine in 2025 (besides Speed Queen)?
whirlpool862
Mar 3, 2025
129
Columbus, OH
I am wondering what washer brand seems to be the most reliable (besides Speed Queen).
I’ve heard that the Samsung washing machines are very unreliable so I’m not going to include that. But out of the three manufacturers (GE, Whirlpool, Samsung).
GE isn’t even their own company anymore, they’re owned by Haier, I’ve never owned a GE washer so I’m not sure about the reliability, I heard that the HydroWaves were pretty terrible but I’m not sure about their newest line of washers.
Why a top loader
There isn’t a top load washer built today that I would buy including Speed Queen, we sell a lot of Speed Queen top loaders, but I sell them to people who are old and won’t adjust.
If I had to buy a new top loader, I’d buy something from whirlpool or Maytag, but an upper end model Not these $500 washers.
For a new machine, I would just simply get a Speed Queen front loader. It’s certainly the best washing machine I’ve ever used, it does everything it’s supposed to every time.
John L
For regular consumer-level top loads, LGs tend to be pretty good across the board. They have a direct drive system that simplifies a few components, and its a feature across-the-board. Consumer Reports has them always ranked #2nd behind Speed Queen for washer reliability, which sounds about right.
Like Combo said, I'd take a frontload over a topload. WM4000's are where its at. But if you absolutely must go topload, go with LG.
I'd avoid the entire Whirlpool ecosystem until they figure out the pressure sensor/transducer issues on the VMWs. The VMAX platform has upto this point, been a spectacular failure and I trust it the least of the direct drive stator systems on the market, and that includes Samsungs.
Haier machines aren't the worst; I regularly use a HWT10ANB1 and I think it washes pretty well compared to other modern HE top-loaders on the market today. Its "high" water setting actually fills the entire bowl and can do extra rinse on any cycle.
Most of their current machines on the Australasian market are designed by Fisher & Paykel, which were a popular New Zealand-based whitegoods manufacturer in their own right before the Haier acquisition. F&P and Haier top-loaders now look very similar.
Honestly the VMAX machines aren’t much worse than the VMWs, although they do seem more prone to bearing issues, but they are less prone to suspension rod issues and control board issues (at least the older VMAX machines). Both VMWs and VMAXs have their issues.
Usually if the bearings are good on a VMAX unit it needs a part like a slider or something cheap. VMAXs leak oil when they go bad but so do VMWs.
I would not recommend any basic Whirlpool top loaders until they revise the models and fix the control board issues.
I would not recommend the new VMAX units, tho, as they have smaller balance rings and worse control boards, and worse diagnostics. They also have a worse user interface, and the sliders on those seem more prone to failure.
GE is improving their machines and I honestly now recommend them more than Whirlpool, I would not recommend buying a used GE of the HydroWave disaster or the Model-T.
The big VMW units, I would not recommend, even the older ones, so many tub problems with those and balance issues. As well as stripped basket hubs, the big VMWs have been a problem since they came out. The new big 4.5 to 4.8 cu ft VMWs have major issues with the pump wires. Ever since they made an “extra large VMW” it’s been a failure, Whirlpool should’ve used the VMAX platform on those. The modern big VMWs are like VMAX units on a VMW drivetrain. The Maytag MVW6230HW for example is a VMW, while the MVW7230HW is a VMAX, despite them both looking similar.
Whirlpool’s older agitator VMW models were so prone to balancing issues that in 2013 they made the balance ring larger but even those tend to be off balance due to suspension rod issues.
Not a fan of anything Samsung, their washers are terrible, their front loaders are even worse than their top loaders. Avoid any appliance Samsung.
The new GE’s are okay as long as you don’t overload it and you don’t buy the high end Profile model that doesn’t rinse your clothes.
The older VMWs seem more reliable, but the newer basic ones are prone to control board issues. I could recommend Whirlpool again but not until all affected models are revised and the issue is fixed.
