I dunno, but I never prerinse and almost all DW over here are cold hookup.
Sure, we could run much higher wattage heating elements.
But most run around 1800W top.
You could probably still run 1100-1200W depending on design.
That is a difference but given the difference between washer and dishwasher, cold water hookup for DWs in the US aren't that incredibly improbable to pull off with barely any difference in performance - given they were designed and more so programmed that way.
Actually, for many US DW, pre rinsing by hand seems even less useful.
Sure I would recommend scraping most stuff off.
But from what I understand, many DW run prerinses depending on incoming water temp.
So if it is low, it would just add another short prerinse.
And for that matter depending on the timing water temp might be down significantly again once the main wash happens.
I think with DW the debate is much more differentiated compared to "wash your week long damp stored towels in cold".
