What Temperature Is Your Tap Hot Water?
launderess
Jul 22, 2004
20,908
It's heating season here (though you wouldn't know it by outdoor temps in 50's and low 60's for past few weeks), so boilers are set to "winter" to provide steam for heating well as hot water.
Noticed about a week ago tap hot water is *HOT*. I mean far to hot to bear for an instant. While this does make for lovely steamy hot showers, and great if one is on a sanitizing jig with buckets of hot water and disinfectant it cannot be generally safe.
Got a thermometer out yesterday and tap water hits 179.8 degrees Fahrenheit!
Thought take advantage of this near boiling water out of tap to run a "maintenance" wash in some of the washing machines. First up was the Miele and it was *NOT* happy with incoming water that hot.
Machine filled alright but first tumble of drum sent scalding hot water shooting up out of detergent drawer. While mopping up that mess noticed water hose was far to soft with connections rather warm. Let machine finish first cycle, drained and short spin, scrub rest! Didn't wish to harm something! Opened the door and huge wafts of steam came bellowing out. Hahahaha!
Won't be doing that again, but to take advantage of this new found bounty of uber hot water will haul out the Maytag wringer and some of those packets of vintage Persil 59 detergent and soap powder. They were made for really hot washes (and a few subsequent rinses as well), so that's me sorted.
I have my tankless heater set to 135.
Pausing here to let the gasping wind down . . .
I've thought about bumping it up to an extravagant 140, but with Dave in assisted living now, the days of really funky wash loads requiring extensive stain treatments are over in this household, and 135 seems to get the job done on whites with boosters added.
My FWB lives in a 4-plex and his hot water is absolutely scalding.  That seems like overkill to me, but since there's just one set of machines in the communal laundry room, if I lived there and had to share them with others, I'd be taking advantage of the super hot washes for sure (assuming the commercial coin-op Whirlpool doesn't dumb down the temperature), just in case the other tenants preferred only warm and/or (yikes) cold.
I can't imagine tap water hot enough to brew tea is good for hoses, fittings and valve components on clothes washers, dishwashers, or even faucets for that matter.
2 central tanks for 60-unit apartment.  Averages 115F.  Paltry, but free (included in rent).
Cold is 80F in summer and passing through lower 60s now.
mine has always been set at 160....
were not full set into the Winter season yet, but I can tell when the outside temp has dropped as I have to adjust the tub knob more to the left past the center sweet spot....
if I was the only person living alone, and had only one machine, I could consider dropping it down some....but there are times of running machines and two showers at the same time with no loss of pressure/temps.....I envy some homes of having two tanks!
104°F is normal (or 103°F or 102°F)
Sometimes 97°F for a cooler shower after yard work.
112°F for a whirlpool-tub soak.
122°F to 125°F for handwashing the non-stick skillet or other items.
115°F to 122°F for warm laundry.
133°F to 140°F (can't go higher) for hot laundry.
I'm surprised that your hot water is that hot, Launderess.  Is it the same for other/all apartments in your building?  I would have thought that the building's management would have taken steps to reduce that temperature due to concerns over liability / duty-of-care issues if someone were to get injured.  Even if the system cannot reasonably provide cooler hot water at this time of year, I'm surprised they haven't installed tempering valves (for example) to reduce the temperature of the hot water entering the apartments.  I wonder if this is supposed to be the case, but your apartment may be receiving abnormally hot water due to a fault/oversight.
I have ours set at 120. When I run the washer or dishwasher I let the water run in the sinks until it reaches that temp, not that I check it too often, but it takes a good minute at full blast. Our laundry is never really dirty, mucky, whatever. If there is a stain on a shirt for example, I'll just spray some Resolve on it, wait the requisite minutes et voila. I guess I'm of the camp where today's top rated laundry detergents can handle the worst and don't require extra hot water.
I agree with both Petek and Marky Mark.
Especially about hot water coming out of the tap at 179F, thats just too damn hot and dangerous! I’m surprised that first of all a landlord would spend the extra dollars maintaining the hot water at this temp and secondly that they would put themselves in such a potentially libelous situation. Someone gets a severe burn and they're gonna call Chetem and Wynn and win big.
And I agree that most modern detergents can remove dirt, grim and germs from laundry with hot water between 120-130F.
When we had our current water heater installed 10 years ago it came with the thermostat set at 120F by law. I requested that the plumber raise the temp to 130F, we met at the middle on 125F and thats been perfectly adequate for our needs.
And 125F must be sufficient to kill everyday household germs because neither of us is ever sick, knock on wood! We keep our home spotlessly clean, use good detergents, disinfectants and other cleaning products and wash the laundry weekly, change the bed weekly, change the kitchen towels and dish clothes daily. The floors and bathrooms are cleaned by hand weekly, no dirty toilet brushes or filthy mops. And the laundry always comes out clean, fresh smelling, stain and lint free by washing everything in 125F hot water.
Eddie
145F at the kitchen faucet.
This works out well since I always run the Maytag Jetclean portable dishwasher on 'light wash' without using the 'accu temp' or 'heated dry' options.  Having the machine parked in front of the sink for 53 minutes is long enough.
Excerpted from a leading consumer reporting magazine
As far as I'm concerned I'll live by they're reporting. Unless someone else can show me any other testing organizations methods and results which are also repeatable.
We tested over 50 detergents, liquids and pods, some of which are claimed to be gentle on sensitive skin or friendly to the environment, as you’ll see in our laundry detergent ratings.
First, we launder fabric swatches that are saturated with blood, body oil, chocolate, coffee, dirt, grass, and salad dressing. We use stains that are exceedingly hard to remove so that we can detect real differences among detergents. Even the best detergents can’t remove every stain completely.
Today's water and energy efficient washers are designed to operate using cooler water than traditional top-loaders from the 1990s. As wash cycles got cooler, the chemistry of detergents had to change in order for them to clean effectively. That's why we test using cool water. We wash swatches in two identical washers with each detergent, then allow the swatches to air-dry. (A dryer is out of the question because the heat can alter the stains.)
Testers use a colorimeter, a device that measures color intensity, to see how much of the stain remains on each dry swatch, compared with stained swatches that have been laundered using only water.
The best detergents we’ve tested earn an Excellent rating in removing body oil and dirt—common stains—but they can also tackle tougher ones, such as grass and blood. Hard water, which has a high mineral content, can reduce the effectiveness of some detergents. We test for that, too, as you'll see in our ratings.
The worst detergents? They're barely better than water when it comes to removing most stains.
Water Temp:
Our 50 Gallon Gas WH is set to 140.
Launderess: Dear Lady 180f/82C is WAY too hot for tap water. You could run a commercial dish machine in that building WITHOUT a booster heater and it would keep temp. That has to be some kind of code violation for a residential building. Agreed though that the MT would be in it's element with this water temp. Could do several loads before the water cooled off.
WK78
Interesting comments,
Thanks guys!
Now you know me, I'm never one to speak out of turn, nor like to stir quiet pools. So unless someone else complains won't be first out of the gate.
Like many other places with steam or hot water heat our hot water isn't from a tank (stored), but a coil off the boiler. In winter when boiler is set hotter (to supply steam for heat) obviously that higher temp influences hot water. There probably is some sort of mixing/tempering valve somewhere, but given temps here haven't been that cold, neither is tap water. So even if there is some sort of tempering going on the cold water isn't bringing things down, or maybe it is within given set ratio, but that isn't enough.....
Over years have commented that in winter boilers give off very hot water. The Mobile Maid DW loves it, and of course when doing laundry by hand or with various semi-automatic (Hoover TT, Maytag wringer....) what could be better!
Haven't attempted doing a "hot" wash in either using this "boiling from tap water". In fact likely won't until can lay hands on a washer fill hose that will withstand such high temps. After today's earlier experiment obviously standard American "rubber" or whatever fill hoses aren't up to the task. European "hot" water fill hoses on my Miele, Lavamat and AEG/Electrolux are rated to 70 degrees Celsius, a temp that is still lower than what comes out of taps. So that's me for you....
Bit of background.....
Yes, one was aware of that fact.
Which was one reason stopped the little experiment earlier with Miele washer. Indeed only use uber hot water temps when doing wash by hand (in tub) or filling same with either of two semi-automatics (the Hover TT and Maytag wringer).
My gas water heater is set as high as it will go. Temp at faucet depends on how much water I use, ranges from 150 to 165. Generally stays hotter in the winter as my whole house humidifier uses hot water, so there is a frequent draw that triggers the burner more often.
One advantage I see -for me - is that I have long runs to the dishwasher and with the low usage of new machines often the water is cool coming in. the very hot water tempers the cool water and means less heating needed. At some point I will add a recirculating system, gravity type, that will save water since the faucet will not have to run as long to get hot water. Water costs more here than the gas used for heating for some reason.
MattL
Your water rates are probably high because it probably is sourced from Lake Huron as is Flints.  Every municipality in the US and Canada that sources their water from one of the great lakes was required to upgrade their sanitary sewers etc by separating them and basically have to bear the costs.  Port Huron rates skyrocketed, Sarnia's rates skyrocketed  .  How the municipality puts the cost onto the homeowner can vary.. Some initially jacked their usage rates up like Sarnia did, which caused people to stop using as much water, so they rejigged it , lowered the usage rates but jacked up the sewer rate and admin fees to compensate.
Exactly. I'm paying $200ish every 3 months for 1 person with all new water efficient appliances. Just put in a new 1.25g toilet replacing the on 3-5g 55 year old original one. I long ago quit using my in ground sprinklers.
Last time I check, the gas fired 50 gallon water heater measured out at 135-140 at the nearest tap. It seems to vary because, I guess, there's a range there.
It's plenty hot for the Neptune washer. The Miele washers sit in the workshop which has only cold water, but they heat it quite well on their own.
And the Bosch DW in the main house takes that 135 water to whatever it needs. Again, relatively efficiently. I usually run the nearest tap (kitchen sink) to make sure it gets tap hot water to begin with.
When I lived in an apartment house building-the hot water was mixed with the cold water to get the temp down and stored in a large tank by the boiler.In one of the apartment buildings-they had two boilers-one for warmed water for heat-the other for hot tap water.The other apartment house had a boiler for hot water only.Your apartment had its own HVAC unit that heated or cooled-like in a regular house.The boiler was not used for heating water-only hot tap water.That place also mixed the heated water from the boiler water with cold water for the "hot" tap water so it was at a safe temp.Another reason for the lower hot temps-save energy and fuel for the landlord operating the building.And in the first place I described they could use fuel oil or natural gas to fire the boiler.They would use the fuel that was cheapest at that time.That place also had a Carrier chiller for AC in the spring-summer.
"And in the first place I described they could use fuel oil or natural gas to fire the boiler."
Duel fuel boilers are very common in north east as well, well in areas where buildings have access to natural gas supplies.
Beauty is that during or after a really bad storm a building doesn't have to worry if oil deliveries are delayed.
In Michigan, the water rates increase in SEMI are coming from storm water charges--they're having to deal with under-investment in the storm sewer system so they charge for the "impermeable" area of your lot. As water here in SEMI is a municipal function, each city/twp can handle it how they wish. We live in a tiny city which is pretty transparent, and the old-guard city manager used the water department and billing as a bit of a "slush fund" to keep everything balanced. It was a several-year effort to get everything untangled. Everyone's water bill around here has three components--water usage (rates relatively linear based on distance from DWSD--Detroit). sewer usage (associated with water usage) and storm water handling. Flint's situation related to their distance from Detroit Water and Sewerage...i.e. expensive, but their water treatment was customized to water with that makeup. When they changed to a cheaper local source for water, they didn't alter their water treatment regime, which then etched the pipes and caused all the problems. Switching back doesn't help, because the oxide coating is depleted. Thus you have a mess---expensive, unsafe water the effects of which are going to redound for generations.
The storm water aspects of things get really hairy, because the problem is the combined (storm and sanitary) sewer system here (and in many larger cities) which gets overwhelmed with the stronger/more localized rain patterns. When the rain is locally heavy, it overwhelms the combined system leading to flooded basements AND spillage of untreated sewage into the Detroit River/Lake St. Clair. All the pavement in the city of Detroit and surrounding areas contributes to the problem--we've got pretty good soil to handle it (nice black dirt) but if it's covered up with asphalt/concrete, the water has to go somewhere. The churches in the city of Detroit are in a particular pickle, as they are assessed for their sqft of parking area and there can be charges of 10s of thousands to account for it.
