Whirlpool 27 Inch Dryers
Chetlaham
Mar 11, 2013
4,244
United States
How well do Whirlpool's 27 inch front filter dryers work compared to their 29 inch top filter models? Do they dry faster, slower, or about the same?
How well are they built compared to their 29 inch counter parts? Are their 27 inch commercial models built different than their 27 inch residential models?
Since I have experience with the Maytag SOH dryers which this particular design is a copy of, they are slower with smaller loads since the air stream has a tendency to go right through. The Whirlpool 29” design is fast with smaller loads since the counter clockwise rotation forces items towards the exhaust outlet while the suction of the exhaust outlet pulls items towards it.
Sean, I've noticed that when I curiously ran the dryer with the door open. Items are tumbled toward the exhaust and even briefly sucked over the opening before being pulled away. The 29 inch design seems to outperform every dryer ever made. Which is a huge victory considering how simple the 29 in design is.
Dan, is that just the 27 inch or the 29 inch also giving rise to trouble? The 29 inch is Whirlpool's bread and butter.
From repairmen on other sites, it's the 29" units that are failing, sometimes right out of the box. The newest ones are having strange heating element failures in just a year which was uncharacteristic of these machines in the past. This is probably a supplier issue more than a design issue. Cheap plastic timer stalks have been breaking for quite sometimes now. Whirlpool is cheapening the hell out of these machines and it's showing. Get an older one and be on the lookout for an NOS timer on Ebay.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?75906
The 27 inch machines appear to have metal timer stalks and rugged heaters- but thats just going by parts stock pictures which may not reflect recent changes. I hope the current 27 inch commercial lineup is that of the Kenmores of the 90s.
Whirlpool dryers
I think their 29 inch dryers sound more powerful compared to their 27 DOTT dryers. As a side note, I made a call to Speed Queen and suggested that they'd start branching out into dishwashers for the kitchen.[this post was last edited: 2/3/2025-21:28]
Since I’ve been using Maytag HOH’s exclusively since 2019/2020 (have brief experience with my Whirlpool Imperial dryer, but is currently out of service at the moment), no real complaints about them since everything comes out to the dryness selected. Loads of laundry regardless of size in a Maytag HOH are always in the air stream.
I remember trying to put the belt back on a Whirlpool 27” dryer years ago, was a royal pain from what I remember.
While the Whirlpool 27” dryers have their advantages, don’t dry things in filtered incoming air like some of the Maytag HOH’s. Recently added this air intake filter to mine, things do smell cleaner since items are dried in filtered air.
chetlaham & Sean
The one we have now is a 27" Lady Kenmore from 1988. My parents are wanting to find a matching dryer to this 2006 Whirlpool direct drive we just put in. I know I've seen some 27 inchers in the slightly older silver panel models from circa 04-05.
Sean, you said that filter goes in the intake? Is that a fire promoter? (not fire hazard, that would be a hazard to the fire, har har--for those who know where that line is from)
I'm trying to remember exactly when I bought my 29" Whirlpool dryer. I'm thinking it was summer of 2019... MAYBE summer of 2018... it was definitely one or the other...Either way, it's over 5 years old and hasn't given me a bit of trouble. KNOCK on wood. I do notice when I turn the dial I'm CAREFUL...not that that helps... I will say this, although they are the same design for decades, it does feel cheaper... but I was expecting that because everything is cheaper.. but it doesn't feel like it's gonna fall apart .. not that kinda cheap.
Whirlpool designed and built 27 inch wide dryers
These were introduced around 1988, whirlpool's of course still supplying all the laundry appliances for Sears and seers ask whirlpool to come up with a dryer that was narrower so that they didn't lose sales to GE Frigidaire and other makers that had smaller dryers, the other design concern is they wanted to dryer that could be vented in all four directions down back right or left both gas and electric Nobody else had that at the time.
Whirlpool has produced many variations of this dryer when they started selling front loading machines they matched the 27 inch dryer to the front loading machines.
This has been an excellent dryer mechanically and performance wise since the beginning, another important criteria of the trier was to get the heating element further from The clothing for greater safety, these 27 inch dryers have four rollers under the drum to support it as a result. You almost never see a bad roller on a 27 inch dryer because of the even support. The 27 inch dryer was not copied from anyone else, some people think it looks similar to a May type, but Maytag uses poor quality slides at the front ride directly on a painted drum. They use plastic blower, housings, and plastic in our doors, it's not the same dryer at all.
GE usually still puts their heating element behind the drum a much more dangerous design. They also use a cheap little plastic bearing in the center of the heating element, great design and a plastic support at the front of the drum, which is the biggest service issue on GE dryers to this day.
As far as durability of the new 29 inch dryers yes the timer that has a plastic shaft has had some problems generally in life some things get better some things get worse, note the plastic shaft is not breaking. It's just a different time or design and they generally suffer contact problems inside the timer has nothing to do with turning the timer too fast or hard.
I have seen no reports of heating element problems being any more frequent on 29 inch dryers or any other problems for that matter. It's still one of the simplest and best performing dryers for the money.
John L
Reply #11
The filter is on the rear panel, not fire prone since the heating element is located at the very front of the machine. The older ‘58 to ‘64 Maytag HOH’s came with an intake filter. Here’s one from the archives.
Putting a filter over the rear intake air
Is something that would never be done today because it could certainly present a fire hazard if it wasn't kept clean and the fact that they put it inside the rear panel that you couldn't even see it made it a particularly bad idea where you have to remove 14 screws to even see it.
It's easy to see why this idea did not last long, if they had wanted to do such a thing it should've been on the outside of the machine where it could've been at least easily observed and cleaned even then because it's on the back, it was not an idea that was ever going to last.
John L
The 27” dott dryers on paper are the better dryer in my opinion. When I’m out doing service calls I love the 27” model because I don’t have to move the dryer at all for service. Everything is front access. It also always fits on delivery. Overall I think it’s a better built dryer.
The 29” is renowned for its simplicity. Like John said, the timer shafts are plastic, but they rarely break. It’s the contacts that give the trouble.
