For the last ten years I've had an Admiral ADG7000AWW dryer. It's been a good workhorse with no problems until last Saturday night when the original belt broke. I pulled the belt and sourced another OEM Whirlpool belt that I installed this afternoon. It has to be done mostly by feel as you can't see the pulley end of the motor with the drum in place. Before starting the dryer I rotated the drum a few times and everything looked good, then buttoned up the front panel and tried it out with the top open. Again it looked good, the belt was in the same place on the drum as before. Before doing any wash I ran the dryer empty a few minutes, then ran a load. Once the dryer was full it popped the belt off after a few turns. So I pulled the drum and found that the pulley on the motor had fractured. I'll buy a new pulley this week but wondered if anyone here has done this repair on a Whirlpool made dryer, and if there were any issues removing the remnants of the old pulley from the motor shaft and putting the new pulley on. From the pieces left on the shaft it looks as if it is screwed on to a threaded part of the shaft, is it safe to hold the plastic blower blades to keep the shaft stationary while doing this? Thanks very much for all replies!
