kenmoreguy89
I brought in the whirlpool belt drive aafter It sat unused for quote some time and It started leaking
I'm positive it is the bolts holding the outer tub to the base, i can spot water in between the bolt inward lodging and the outer tub surface and water couldn't end up there, it seems It is especially one on the rear right side (looking from the back) and It runs above the "skirt-base"
probably it is two of them leaking as i see water on the front also but not sure (even because i have no access to really see the front)... Looking with a torch i spot no water toward the center drive area and nothing comes out from the holes in the center and can't really see it being wet in there... so guess is not the tub seal which i should be happy for I guess.
I do not have a spanner nut tool at the moment to remove the basket and see what's under there and check.
Are all spanner tools the same or there is a specific one for older models and newer models?
I have seen in some pictures of restorations that there are two bolts having a seal and two do not. Is It possibile?
It seems to me that the leaking ones in my machine are the ones with the seal.
Do these seals have a part number?
