Whirlpool Cabrio Problems. NEEDS HELP!
lostuser1399
May 9, 2020
Florida
My Whirlpool Cabrio HE washer is not working and I dont know why, I've had someone check it out and they also didn't know what was going on. When I turn the washing machine on its set on the setting that you see on the picture (Mixed with 52 min) but when I try to change it or even start the wash it wont let me, when i touch a button it doesnt change anything it just gives me two beeps. Every time i run a diagnostics test it always gives me different codes and ive tried unplugging it completely for a whole day and nothing.This happened before and it randomly started working with only the Casuals setting on but it stopped functioning again.
I only see 52 and hear two beeps.
Here we go
For the WTW8500, should be usable for your machine just as well.
https://www.manualslib.com/manual/1244310/Whirlpool-Cabrio-Wtw8500dc.html
Page 11 lists your issue as 3rd one from the top. Appears to be either a broken connection or an issue with either the UI board or the main control board.
If it is either board you are looking at 200$ or more (from a quick search even more likely 250$).
There are board repair services that might do that for 100-150$, but don't quote me on that.
