Whirlpool Cabrio
Bobby, you have the original pictures. Maybe they are easier to read than the pictures that appear here. What do the panels actually indicate regarding water levels?
My best guess at what the panels read (top down):
Panel 1:
AUTO
SUPER
LARGE
MEDIUM
SMALL
LOAD SIZE?
Panel 2:
HIGH
MEDIUM
LOW
"ILLEGIBLE" (maybe EX/LOW?)
WATER LEVEL
Emilio
On the HE models (Panel 2), the water level is replaced with a spin speed modifier, as the water level is unadjustable on the HE models.
The speeds are:
HIGH
MEDIUM
LOW
NO SPIN
From the Whirlpool Rep: when on auto water level, the machine does a quick burst of water filling to the machine. The longer it takes the water to reach the sump to trip the sensor,the more water the machine fills with. all while slowly spinning the tub.
Thor, Yes the water levels are:
Auto
Super
Large
Medium
Small
Panel 2 is the tempreture options, and the first is the Soil Level.
Very cool, love that window lid model!!! I noticed this machine doesn't have ridges on the upper circulator column of the agitator, whereas the similar Oasis does.
As for the agitator/disk being interchangeable, I can't see why not. F&P uses a low post drive, and the disk is fairly high in the center, higher than it would be for a normal wash impeller. I pulled the cap off and found the familiar Kenmore 7/16" agitator mounting nut.
Just my 2 cents.
Quality of wash in the Cabrio washplate
What kind ot wash quality will the washplate produce on heavy soil loads does any one know? I am thinking of buying one of these . Also does the hot fill use the true incoming hot water temp if it 150 of so does it temper it down.. I hate that . Sudsman
