Whirlpool Design 2000 won't drain
carmine
Oct 15, 2010
211
Detroit
Hello all. I can't get this washer to drain, and I'm just about to put a bullet into the front to expedite the process. I'll take one last shot (pun intended).
It would fill/agitate, but then seemed to pause when it should have been pumping out the water. I would advance the timer by hand and it would agitate again, but stop once more when it came time to drain.
I removed the timer and found a connection that had obviously been running too hot (upper right in photo). Could something jam the pump? This afternoon I'll try tipping it over to see if I can find anything obvious.
Is the pump on this purely mechanical, driven by the same motor as the agitator? I wouldn't have much trouble cleaning up the harnesses/timer, I see this kind of damage all the time in cars.
