stricklybojack
The situation is it doesn’t run. No hum, no nuttin’.
Previous owner trying to track down the problem replaced the timer and start switch then gave up.
I was told it “is only a couple of years old”.
I checked the door switch for “click” and continuity, and also the thermistor on the fan assembly. Both were fine. Drum turing well, belt fine, etc.
What next, start button relay? If so, is that in the control panel?
