Lovepuppy and Kevin -
I know that Charles was looking for my reply sooner than now, but I've been traveling this weekend and been getting myself back in gear here.
So, first, YES, what a great looking set, via phone pic or not. They look great.
Personally, I love these machines, and have been having my laundry washed by one model or another similar my entire life. I would not want anything else to be honest, I simply truly enjoy them.
As to this machine, my first thought would be to say the pump for sure is probably bad, and the belt. These are not bad or expensive items to replace just due strictly to age.
However, there are other things that could be causing a leak and a no or slow-drain condition. Kenmore81 is right in that the outlet hose to the manifold trap could be leaking. This is far more common on large capacity machines like yours than standard tup models which have a different outlet hose which seats better.
You could also have a leaking lint filter. If it is clogged and/or cracked, this could be your culprit.
There is a variety of good news with all this as the pump and belt are still out there available from Whirlpool. The outlet hose is not, but they can be found and I know Kevin has one as I directed him to buy one or two recently. Ok....I almost insisted.
The lint filter might be a tough beast (probably NLA), but I saw one on ebay last weekend. These were used by Whirpool only as Kenmore had their own design they liked. Whirlpool's filter is molded as part of the manifold trap, and sometimes shakes loose and makes the outlet hose leak.
If this were my machine and I wanted it to live on a good while yet, I would pull the tub and replace the centerpost grommet (Kevin is familiar) and the tub outlet hose. At the same time, I'd change the belt and the pump. I know Kevin has changed pumps, but a belt too?
This can be a bit of work, but there are folks, including me and Kevin, who'll help. It wouldn't be the first time I was on the phone with Kevin doing mobile washer repair consultations
GOOD luck!
Gordon
GOOD luck!
Gordon
