shawn1972ut
- Joined
- Dec 8, 2013
- Messages
- 4
My 13 yr old Whilpool washer was not agitating, so I did some online troubleshooting and ultimately replaced the coupler (plastic was broken) and agitator dogs (they were worn). When I ran a test cycle, it filled correctly, agitated better than it had in years, and drained effectively prior to spin cycle.
Once the spin cycle started, there was an increasingly loud "whining" noise (metal sliding on metal) --- vrrruuump, vrrruuummmp, etc as it increased speed. The drum spun fast and correctly, but the noise was a new problem that had not occurred in the past.
I took apart washer, verified that I'd correctly assembled, and tested again WITHOUT agitator attached, to see if I could better identify problem. As drum spun, I could see that center post (where bold holds agitator in place) would "slip" and that was most likely the root cause of the noise. Note that the ridged post would spin, but not as quickly as drum.
Based on online research, there seem to be a few possible issues. All of those issues tend to increase in cost for parts, so I want to be a bit more precise and not start replacing things that aren't necessary.
Fact that drum spins and agitates effectively leads me to think it's not clutch.
Worth noting - for years, I've had some type of brown-gold lubricant leak, which I've always assumed was basic grease. Its just a think film that develops under washer, so its not a "big" leak. This *may* be a contributing factor, but it's odd that noise wasn't a progressing issue (e.g. started long ago and increased in severity over time).
Can anyone help me narrow down to true failing part?
Thank you,
Shawn
Thank you,
Shawn
