Whirlpool Repair Question
suds14
Jan 27, 2008
182
Pittsburgh
I have a whirlpool washer model#LPA7805W2 with suds saver that won,t drain when spinning or the rinse water. I replaced the two way valve and the washer will pump the wash water out the suds hose, but when the timer goes to spin the water does not pump out the drain hose, after a while it will starts coming out of the suds hose. The water will return to the washer on suds. I do not think it is the pump. Any help or suggestions will be greatly appreciated.
Thanks
David
Timer?
It sounds like it could be the timer. Can you hear the solenoid closing when it goes into the spin? It should make a klunking noise if it is working properly. If it's the timer the switch in the timer could be broken and staying on. Good luck finding the problem. I have used sud savers for years and never had this problem. Check the hoses for kinks inside and outside the machine too. Am looking forward to hearing what the problem is.
