I have a whirlpool washer model#LPA7805W2 with suds saver that won,t drain when spinning or the rinse water. I replaced the two way valve and the washer will pump the wash water out the suds hose, but when the timer goes to spin the water does not pump out the drain hose, after a while it will starts coming out of the suds hose. The water will return to the washer on suds. I do not think it is the pump. Any help or suggestions will be greatly appreciated.
Thanks
David
Thanks
David
