Whirlpool
Whirlpool!
I had one almost like it in my first apartment - it was a model lower because it had the dial for temp instead of the buttons. It also had the brush lint filter it was 18 lbs from 1974 machine. Really great washer.
Peter
Rusty Whirlpool
So, here it is, in all its rusted glory. Just picked it up yesterday for free. Other than the cabinet, everything else is in good order, just that it sat for many years on a back porch so the belts disintegrated. I did plug it in and it works fine -- will probably part it out, but might be a fun restoration. I didn't realize it's an 18-pounder -- nice capacity.
More pics
Another angle of this Harvest Gold beauty. Fun dial console, and cycles are: Normal, Knit, Gentle and Permanent Press. Not sure what the difference between Knit and Gentle would be -- the lid instructions don't go into cycle detail...
Knit cycle has a 1-stage cool down ... after wash there's a partial drain, refill with cold water, 2 mins agitate, the continue with the normal rinse & final spin sequences.  This as compared to Perm Press which has a 2-stage cool down, and Gentle which has no cool down.
It this machine an LAA or LDA model?
Glenn is right on the money
the cool-down in the Knit cycle was a real surprise. I have the same machine, rusted almost in the same spots. I had pix & stories in another thread, which you missed. It was the day before you found this. Cool coincidence, Todd. These beasts are indestructible. The surgilator is standard, not super. Enjoy this machine, very versatile, lots of fun, tons of room in the tub. See L's thread #38158 Funny Whirlpool advert.
Solid Seller
If I could get one of these when I was in business in the '80s, it would sell quickly. It was a good reliable machine, and people liked the features. Some of them did rust, however.
Whirlpool Lid Switches
How come some whirlpools have the lid switch on the right side of the door and some have the switch hidden behind the door? The 72 whirlpool supreme 80 set I remember growing up had the switch on the right of the lid (very convient for easy by-pass), and the 72 whirlpool supreme 80 set greg saved for me has it on back of the door? Why were some made one way and some another way?
My husband says it's a rust bucket and part the thing out, but I'm thinking with a 2 x 4 reinforcement behind the rusted area, it should be solid. Everything else looks good -- just a couple of belt replacements. I'd love to see this thing up & running again and I just happen to have a little room in the wash house for it...
Before going too far it would be a good idea to make sure the outer tub is in
good shape and not leaking over the base plate. Also check the pump (right at
the pulley bering) and see if there is any signs of leakage.
I ran into a quite a few where the pump would seep
some water onto the belt during wash or rinse cycle. You wouldnt nessearily see
any water on the floor because it wasnt a large amount.
But the belt would then pick the water up from the pump pulley and sling it
on the side of the cabinet and on to the transmission causing quite a bit of damage.
