Why Did Older Dishwasher Have Such Enormous Motors?
Chetlaham
Mar 11, 2013
4,921
United States
I mean why were they so big considering modern dishwashers get dishes clean with a 50 watt motor?
Why not make a two port sump (think plastisol tubs) and add a removable find filter basket?  180 watt wash pump like this:
https://www.ebay.com/itm/GE-Washer-...859077&hash=item48efbcb1f7:g:~4kAAOSwNGNfiKqT
And a 25 watt drain pump like this but in shaded pole version:
https://www.ebay.com/itm/GE-WD19X10...847747?hash=item2393e0f083:g:xygAAOSwLsBZVTHc
Frog eye or cat eye spray arm with small holes. Continuous advancement timer (like on GE machines) where the drain pump starts and the wash motor shuts off 30 seconds latter. Similarly after the drain pump shuts off, fill starts and 30 seconds latter the wash pump comes on.
I think this would have been cheaper, used less water and reduced carry over water found in many designs.
Why not have gone this route? Speed Queen could pull if off today if we wanted a no frill machine but also respected modern design.
i'm of the old school
i have a lot of old dishwashers and the bigger the motor and the more water they use the better in my book! but i'm into them for the nostalgia of it. the old hobart kitchenaids had 1/2 hp motors, the gold seal motor they called it. i have a bunch of kitchenaids, over 20 and i have never had a problem with a motor yet! i've had lots of other issues, but not those powerful motors. hobart used to advertise them as lasting longer because the bigger motor would be under less stress.
and i think the rest of them used 1/3 hp motors, most of them 3450 rpm, but hotpoint used a 1/3 hp 1725 rpm on it's old machines, i have 2 of those plus one new extra motor. they used a big wash pump with a big water slinger impeller since their motors ran slower. but the g.e. mobile maids used a 3450 rpm 1/3 hp motor.
not sure what maytag and whirlpool used, although i do have a maytag front load in harvest gold from early 70's that has a horizontal pump and motor and it's gotta be at least 1/3 hp i would guess.
i would say back in the early days no one was concerned about energy usage and the idea was to build these machines to last which indeed they do or we would not have all these great 50 year old machines still working fine! and they had powerful pumps and used a lot more water because again no one was worried about water usage. these new machines i have no respect for, they drizzle a cup full of water around and take 2 hours to do a load, please! give me a water guzzling kitchenaid or frigidaire any day! but then i only run them for hobby so energy usage is not an issue. at least with me.
manufacturers definately believed bigger was better!
Big motor + lots of hot steamy water + brute force + phosphates + bleach was how the dishes got cleaned in a timely manner.
Whirlpool Ultrawash/Power Clean dishwashers were still using a 1/3 HP motor through 2010. Detergent with phosphates and bleach were available through 2009, so it wasn't all that long ago.
1/3hp = 250W
More power usually means more water moved at higher pressure and/or speed.
Modern DW actually do the same often: Variable speed pumps often ramp up for intensive or quick cycles.
Efficiency is another matter:
While motors in general are relatively efficient, these motors more often than not were asynchronous motors - probably the "least efficient" of all of these.
Still pretty efficient (over 90% I'd guess) but not quite what today might be possible.
So you'd have to subtract that.
Efficiency of water path designs and pumps themselves were lower as well.
Fluid dynamics is a complicated and frustrating science.
Without computer simulation optimization was just not quite at the point we got to today.
Detergents just called for high mechanical action and large water quantities as well.
They weren't quite at todays standard, so more solvent (water) and more movement of that just forced things along.
And silence and efficiency just weren't jet asked for.
Getting the job done well was the first task.
Then they looked at makeing the machines cheaper.
Then efficiency came up.
Adding the lack of alternating spray (efficiency addition) and you could probably equate 100W today would be equivalent for 250W in a machine back then.
As one one of the few who still uses a portable full-size dishwasher that get's parked in front of the sink, I appreciate a machine that finishes in a reasonable amount of time.  My 18 year old Maytag Jetclean portable runs for 51 minutes on 'light wash' and does a fine job.  I dread the day that I have to replace it.
1/2 Horsepower Motor
The KitchenAids from the 15 Series to the 21 Series used the 1/2 Horsepower motor that was made by Hobart. Once Whirlpool took over KitchenAid, I think they eventually made these dishwasher motors weaker.
I can verify that even when “evil” Whirlpool took over KA, they still had “gold seal” 1/2 hp motors up to the 23 series.
Only in the 24 series fully on the PC platform is when the motors went to 1/3hp.
KA DW Horsepower
The KD10-14 machines had a 1/4 HP motor and the KD15-22 machines had a 1/2 HP motor.
Whirlpool did claim that the KD23 series had a 1/2 HP motor but it was the same size as the standard WP DW motor which was rated at 1/3 HP.
These large split phase motors were reliable but only about 30% efficient at best at converting power used to washing power.
Reply #10
Hans, wasn’t that the particular model you mentioned at the wash in back in 2019 you “wouldn’t miss more than an abscessed tooth” when I asked if you missed that particular model of dishwasher?
@ Reply 4
This.
My wife and I have a portable Whirlpool that hooks up to the sink. I'd take a venture that it's close to 30 years old, if not more. It's loud. It uses a ton of water. And I guarantee you that it cleans better than anything currently on the market. It's not a Power Clean (it's actually kind of basic? Maybe an MOL?), but it'll blast the crud off anything you throw in there.
Contrast that to the fancy, HE-style dishwasher that we have in our timeshare, which takes HOURS to complete a load, and still leaves the dishes disgustingly wet.
We don't care about energy or water conservation. We want a machine that'll do the job well - and fast. We've already made the decision that if this one goes, we'll either find someone to re-build it, or we'll scour the classifieds for a used one.
Older, whirlpool, dishwasher
Hi Steve, what model were portable dishwasher do you have? They made several different styles over the years.
I have two 35-year-old whirlpool built-in whirlpools in my kitchen. I do have concerns about some of the aspects of the new machines they do get dishes very clean, however.
But I like the cycle times of the older ones in the fact that they will wash away so much food soil without ever ever having a filter to clean.
My vintage GE Mobile Maid has a giant whopping motor and can move water like no one's business. No wet wipe dishwashing here, machine actually will shimmy and slightly move about from force of water.
Sadly all that brute force has ruined no small amount of dish and glass ware so that's me for you.
Supposedly now, those smaller motors can do more, maybe with advanced technology doing more than we'd thought--or maybe they're strong to the finish 'cause they must eat lots o' spinach...!
-- Dave
Reply 13
That pictures wells up a lot of emotion in me, including deep sadness and longing. I wish that PowerClean was still being made today. No other dishwasher comes close in the history of humanity. If everyone was like me that dishwasher would be in every kitchen across the globe and the heater wouldn't cut off after the thermal hold... Sadly when the tall tubs were introduced people began buying them and it only increased. Whirlpool was clever, they had the point voyager which kind of mimicked the power clean to help get a certain number people on board with the idea- as if nothing was missing- then quietly switched to the filter design. All around messed up. I dislike how passive and naive people are.
Smaller motors don't do more work, they just run 6 times longer to get the same job done. Instead of 20-30 minutes during the wash and rinse cycles, it's 1-2+ hours. Between weak designed motors to save electrical costs and reduced water levels to save water, dishwashers are quickly heading towards alternating wash arms as being the norm. Probably expect longer cycles times from them in the future.
About 90% of dishwashers
Have been alternating wash arms for over a decade now, this practice fix the dishwasher quieter, allows it to have less water that has to be heated in the machine, and generally does an excellent job
By any measure newer dishwashers today get things cleaner than the older machines ever could that’s the advantage of a long cycle. It will soak things off and then scrub them off that older dishwasher couldn’t touch, except on the very long and energy intensive pots and pans cycles that a few machines had.
John
My Bosch will cease alternating wash arms and run both arms simultaneously for the majority of the main wash if it senses heavy soil.
Yeah, I'm aware of longer cycles cleaning stubborn items. For years, I have posted pics my KDS-18 with an externally mounted switch to the timer motor that I can stall anywhere during the entire cycle. Thing is, stalling the timer just an extra 10 minutes or so during the wash cycle (pretty much doubling it) achieves the same results as hours on a newer dishwasher. It's extremely rare that I burn anything since I was never a fan of consuming hot foods or drinks.
BTW, the home I moved into almost 4 years ago came a Kitchenaid dishwasher from 2012 in the main kitchen. The KDS-18 resides in the kitchenette for occasional fun use now. It's quiet but sucks even with pots and pans with every single option selected. And that's on mechanically softened water. I make and eat a lot of homemade soups and it leaves residue all of the time, every time in my clear glass bowls. I never had that problem with 18 on very hard water and extremely short wash cycles before installing timer motor switch. I'm not worried about the residue as it's clean enough for me but I don't use those dishes when company is around. I'll take pics of my next load. My brother has virtually the identical dishwasher he bought brand new, just with top controls rather than front. I quickly understood why they rinse every dish under the kitchen faucet before putting it in the dishwasher. They get away with using the normal cycle using this method.
Noticed when I mention alternating arms, I said it quickly becoming the norm, not something newly released.
So John, when are swapping out your 80's Powerclean for a new dishwasher ;)
Dan, you bring up a good observation. Higher water pressure (mechanical energy) in a vintage machine can in theory achieve the same results as a modern machine but requiring less time.
With cool water Powercleans did that. At 8 minutes into the Main wash they would do a thermal hold until the water was heated to 140*F which extended the main wash considerably.
Agree, it was a good balance of power, fast time cycles, and clean results. A couple of other designs had the right balance too but the reliability wasn't there (mainly in the electronics), like some of Maytags post RR dishwashers.
Most users today want a dead silent machine and it's just not happening with a 1/3 HP motor. The EPA wants the machine to use a trickle of water and electricity which throws more obstacles into the game. Manufactures today want to build the platform as cheap as possible and have it last just past the warranty and die soon after to boost profits.
And here we are.
to chetlaham
I will never forget when my mom said, "This dishwasher sucks!" Mind you, this was in 2008. There was crud stuck in the glasses in the corners, forcing us to use pots and pans and soak and scour for everything. This wasin the Whirlpool Gold dishwasher. My mom got a Kenmore back in 2011 which was the filter design and it did clean the glasses, shockingly. It was the new filtration design. the Whirlpool point voyager went to my dad who used it from 2013-2016. Sadly, nearly all dishwashers use that stupid alternating wash arm action, even Maytag. This is a sad state of affairs as far as I'm concerned.
Sadly, all true Dan. Big motors are noisy and reduce capacity at face value- so few want them now. I say at face value in that while a tall tub can hold more dishes, nothing is gained with any type of scrubbing, pre-rinsing, or pre-washing as with so many of today's tall tubs.
Nothing can outperform a Whirlpool Power Clean Filter module. It is the true definition of loading baked on, dried on, nasty without any type of pre-treatment coming out spotless with minimum water and energy.
The following is what a real dishwasher looks like. Simple and cheap, energy efficient- yet long lasting lasting, no nonsense, and 100% clean.
40 minute main wash, heater runs the whole time to achieve temps in excess of 150*F, lots of pressure and water movement, plus the famous soil removal, retention and flush away of the PC module.
The fact that nothing like this has ever been built is everything that is wrong with the world.
Enjoy! :)
Real Dishwasher
Jerome, want a real results? You need several things:
1) Main wash water temps over 150*F, preferably 180-190*F.
2) Main wash times of at least 30 minutes, preferably longer.
3) water volume
4) water pressure
5) multi directional targeted water distribution
6) strong maceration
7) High capacity fine filter
8) particle flush away
9) Long heated detergent prewash (if needed)
Every dishwasher ever sold has been some combination of these 9, but never has anyone actually sold a dishwasher that managed to meet all 9 in the high notes despite being feasible with minimal engineering.
People are being sold jokes Jerome that always manage to come centimeters close to the itch but never actually scratch it, thats for sure.
to chetlaham
Sadly, most joes and janes don't care. As far as they're concerned, as long as they're silent, it's fine with them. I want to hear my dishwasher doing something at least spraying the water around. That's how I know it works. Period. This is why I wish dishwashers had clear glass windows.
Well I think to a degree they do care- you've got folks pre-rinsing without fully realizing its a reaction to the fact most modern dishwashers (and even some old ones) just can't clean like a Power Clean Filter Module, Hobart Kitchen-Aid or Maytag JetClean.
If everyone was like me the Power Clean Filter Module with the above wiring diagram and cycle sequence would probably dominate being in 98% of all Kitchens. I say probably, because chances are that Power Clean Module would be complimented with a water inlet temperature booster and a second set of fresh water spray arms as seen in commercial dish machines.
Ignore the the energy star label, its won't mean a thing in my world ROTFIL!!!!!!!
