Why Do All Speed Queens Spray Rinse While Full of Water?
Yes they do, they make the Mechanical 300 and 350 models. I'll put a link to them down below here. But on a side note, I wouldn't worry too much on the electronics. Sebo has proven to be one of if not the most reliable vacuum companies out there just like Speed Queen. Even if something ever did go wrong, they are super easy to fix. And Sebo unlike most vacuum companies out there, they actually make their vacuums even better than they ever have been before. Personally, I prefer a Sebo vacuum that uses electronics. Same goes for Speed Queen washers and dryers because they both would offer more features that the mechanical ones do not have. Example you can turn the brushroll off, the height would automatically adjust, the vacuum would shut off if the bag was full or if there was a clog, etc. Feel free to watch a demonstration video of this white X4 that you can still buy today, which is technically a Kenmore Professional 12 but newer and branded as Sebo.
https://www.sebo.us/upright-vacuums...nical-heavy-duty-reliable-vacuum-cleaner.aspx
Just like the machinery, not all electronics are created equal.
Do you think a company like Whirlpool, that obviously no longer cares about quality, is going to make washers out of tin and plastic that is designed to break, and then use the highest quality aircraft or automotive-grade electronics?
I would choose mechanical dials if I could, because I think of them as being tried and true, and I'm resistant to change. However, it's becoming more impractical, or impossible, to do so if buying a new machine. But even if Amana had mechanical dials, I would still chose a Speed Queen with electronics over it every time.
Very true unfortunately. Whirlpool knows their main parts (belt, shifter, splutch, tub seals, suspension) will only last X amount of cycles, so anything else like fill valves or electronics will be engineered around the same life expectancy.
In a perfect world appliances would be like the cars in Cuba. Still going strong after decades, going a step further in that they would be designed for refurbishment vs replacement at the 30 year mark.
Yes, there's a motor that levels the height adjuster while being controlled by a circuit board. It's like your Kenmore Intuition where there's a circuit board to control the motor of the brushroll. This video would give a proper explanation of why this is important to have on a vacuum.
Neither Mechanical models can do that feature, that's one of the reasons why I prefer the X models.
Your not wrong! Fast spin + 2-3 minutes of spin-drain before initiating spray is ideal IMO.
The exception I feel would permanent press, where the spray would start at the instant the pressure switch is reset and run until the spin stops and the tub fills up for the rinse just like with GE filter flos. GE had a nice thing going, and with Speed Queen's targeted fill flume would in essence perfect it. Simple, easy, beautiful.
Lots of good could be done without energy regs and common sense engineering.
Also, let me be the one to apologize for your downy ball not opening. That makes me sad when I think about it
hard feelings
I have no hard feelings towards Speed Queen. I just wish they'd left the spin speed at high speed when using normal cycles. It will open the downy ball if you do smaller loads. I stay near the machines to open the ball, though it does tend to leak out into the tub as the water fills. I just open the lid and press the weight down.
I'm glad to hear your not taking it as hard as I am. But hey, hard feelings can be as good as they are bad in that I find feelings drive constructive reform leading to a better future for all.
I'm glad to hear its working on smaller loads. I would not worry about softener leaking into the outer tub. In theory the pump running in reverse during agitation will kick any softener back up into the outer tub if it had migrated into the pump during fill. This is why it is essential to have the pump running in reverse when agitating. A drain pump with a one way impeller makes for poorer performance and shouldn't be used in a washing machine IMO. Whirlpool BDs were the worst in that the pump would drain water out of the machine for 1 second at the start of agitation. I can imagine some Woolite, liquids and fabric softeners having been pulled out of machines millions of times when users added liquids to the bottom of the wash basket. Having the pump directly attached to the main motor was done for many, many brilliant reasons and this is one of them.
@MobilMade: That is probably the idea, however, IMO to many variables are at play. I like the idea of letting the tub go into full spin then add water like all the other major manufacturers. Though you not wrong, this is probably Speed Queens exact line of thinking.
@gelaundry4ever: I hope you're Downy ball works out on low Speed!
Glad to hear you can get a deep rinse and the downy ball opening. Both get the job done.
Do you have pictures of those coin-op Speed Queens? Anything Speed Queen is a luxurious experience.
Lots of error codes, early break downs, no serviceability, hard to find parts, detergent stains, wrinkling, lint, unclean clothes, streaks, pilling, tears, tangling, twisting, discoloration, gunk, very long cycle times, smells, creepy noises, annoying noises, features that will never be used, confusing controls, locking lids, loads that go off balance easily, materials which break just by looking at them, states of befuddlement where one is not sure if the machine is working correctly, incorrectly or transmitting telemetry data to China.
Yes I'm aware detergent staining shouldn't happen with dispensers however I don't use built in detergent dispensers. A good machine doesn't need them. I just throw the Tide Pod underneath the water fall or add detergent to the bottom of the basket as the machine is filling. Then add clothes. None luxury brands don't let you do this because they want to play with the dry clothes for 10 minutes first then spend another 10 minutes judiciously creating pseudo moist wet naps. Lots of intermission breaks in-between too. Got to let the clothes age then marinate before moving to the "wash" portion of the show.
Exception in my heart is the GE Filter Flo, just add detergent to the pan and you get a real no nonsense detergent dispenser.
Don't even get me started...
On undissolved or undiluted fabric softener. With true luxury brands like Speed Queen, fabric softener gets mixed in with the water thoroughly. I noticed you get a subtle laundry detergent and fabric softener without itching or oilly feelings.
Water and distribution is key. Granted some, actually a lot of people overdose HE machines but at the same time the machine isn't all that innocent either.  Speed Queen pays forward a conscious user. Even Whirlpool TLs fail to do that releasing the fabric softener halfway through the first spin and then a spray rinse in the final spin.
