Hi Gary,
I think you would be quite right as there are probably quite a few failing because of the contrarotate not working, or main bearing on it's way out. Had these machines been released a few years later then the drum parts issue would probably wouldn't exist because of Chinese sourced parts.
I think a lot of the problem would be the liquid detergent / fabric softner build up on the spiders. Causing rotting. There were a few locating pegs for the smaller inner shaft that were gone because of this decay.
All I can say is get one cheap and have a play, it is worth it just to have a look at what goes on.
D2D, i'm guessing that your CR02 had later software than mine as I don't get that kind of read out on diagnostics. Have to say they were a bit late in doing this info as my Zanussi displays that kind of information and that was built in 2001. Would have though Dyson would have nailed that.
It would have been good if they had tried doing a more conventional style to capture more sales, as it was a bit of a marmite.
