Winter Tap Water Temperature Check Thread
qsd-dan
Jan 24, 2007
7,788
West
Post up your winter water tap temps!
Current tap is 63.6F (phone is playing a new game of refusing to let me rotate pics 😔)
Ran a load of cold water wash in the HA806 and wanted to check tempering valve operation and verify it's still functioning accurately all these years later. The valve is set for 85F, it's adding 22.2F to execute that setting. My love affair with that valve hasn't weaned the slightest in nearly 20 years. LOVE IT!20251223_133756.jpg
I ran my kitchen faucet for a minute and stuck my accurate digital Taylor meat thermometer under the running tap....
48.3 degrees
Now, Dan, how bout taking a nice cold shower in my bathroom?
:eek:
The thought of that is making my genitals crawl into my throat šŸ˜†
You need to add tempering valve on that Maytag washer, nothing is getting clean at those temps! Even warm probably isn't breaking into the 80's.
LOL!
Ahh... Dan, thanks but my Maytag's doing just fine.
Warm or Hot are the only selections that I use. (with my "warm rinse" turned on)
I ran the cold water in the basement laundry tub over the probe in the digital instant read thermometer until it stopped descending and it stopped at 50.4F. It will probably get colder, but even now the tempering valve is using a LOT of hot water to bring the cold discharge up to 85F and that is turned down as cool as possible, but I can't imagine rinsing, let alone washing in 50F degree water. I was amazed and thankful when John found those valves at the donation store years ago.
Our kitchen pipes are close to a heat vent. It takes a long time to get water main temp. water to the kitchen. The meter is on the opposite end of the basement. 30 feet.
When it's winter (in Argentina), my neighbor can measure 112F at his kitchen sink tap. The main got replaced some years ago, and is evidently only a short depth from the pavement. I think he may be exaggerating a bit, a 112 degree shower will leave you all red...
