Winter Warmer Meet & Vintage Keymatic Fix November 2019
Some advancement, timer works and energises cams & contacts but is stopping on a certain position, time to crack open the timer again, its been a long day, long nights, time to call its quits for tonight and have dinner..and drinks...discussions on next steps and laughter !!
Around the table for a hearty supply of home made veggie chilli, baked potatoes are L - R Walter (Supertwin59), Saj, Steve (SESteve) Mark, Mathew (Keymatic3203) Alistair the host (Vacbear58), Ian (TriumphDolomite), Jamie, Liam, Rob (RobM) and hiding Mark (MarkyMark) and Jon (LavamatJon)
Good time had by all...
But we dont know whats underneath that when split open , on the bottom parts is the circuit contacts to which the wiring loom connectors plugs, (which those where ahead of their time in regards to other manufacturers machines which used individual crimped wires on their timers) instead of Hoovers block connectors.
To our complete surprise its a circuit board, never seen anything like it on other timers of the era, Star Trek next generation here we come, John Hewett is a Hoover Engineer who owned a Hoover Service Centre in Cheltenham and he says that if these went wrong they where simply swapped out and returned to manufacture for replacement and credit, If a customer needed to buy one out of guarantee they charged £4 pounds a replacement timer which would be £88 pounds in todays money !!
Here is the wheel driven by the clockwork motor from above and attached are the two sets of four contacts that make contact during the revolution of the wheel on disc to provide the right energisation of components ie, fill heat wash pump rinse and spin..ingenious..
On the side of the wheel segments are the numbers of the 1 - 36 positions which can be seen on a tiny viewing window on the side of the timer, this helps diagnose faults through timer position..
Alas it had also blown the remaining resistor ( having ordered 10 of the right type but delivered the wrong Ohms ) so as this was the end of day two and no bank holiday the time flies and we leave it untill next time, new resistors ordered awaiting fitting, also the heater had blown continuity so there is a UK manufacturer who manufactures new heaters to shape and wattage of original for a reasonable fee thats being ordered as well . So...To Be Continued !!
