Work begins on the1957 Speed Queen TOL
Looks great Jon! I knew you would have that bad boy up and running in no time! Congrats on your 57 Speed Queen restoration.
Jon ! I could EAT this machine too !
It looks and Sounds so GOOD !
What a great job on time , patience,
and learning from the experience.
I hope one day I will have the time ..
place and patience and talent to restore or improve some of my or possable machines in the future.
I went all the way to NE Philly for this
sign .
Best to you on the washer.
Darren k
If I may ...
The upper position of the switch is 11 mins (Regular cycle) or 4 mins (Short cycle) agitation time.  Agitation is continuous for the duration of the wash period in the upper position.
The lower position is 7 mins (Regular cycle) or 2 mins (Short cycle) agitation.  Agitation stops for a few of the timer increments in the wash period.  Assuming each increment is 1 minute, that'd be 7 agitate and 4 no-agitate increments in Regular.  Two agitate and 2 no-agitate in Short.
I believe the numbers are color-coded for the respective cycles as a visual reminder to the user -- 11 and 7 in gold, 4 and 2 in red.
The 7 is not clearly visible in this picture, it's at the lower-left across from the 2.
i can't get over.....
how quiet "willie" sounds on the video!!!
very nice there jetcone!!! what a GREAT restoration you did!!! just AMAZING!!!
:o)
It's a time-fill machine and SQ's timer design doesn't provide for setting wash time after the fill, so this switch and timer circuit allows an adjustment for it.  Probably it's a upper-end feature on a TOL model.  My aunt's mid-line SQ of 1969-ish vintage didn't have a choice of wash time ... timed-fill and the wash period was always full-length per the cycle (Regular or Durable Press).
Need another vid jetcone
I'm going through SQ withdrawal and if I don't get my fix, I might switch over to pod detergent!
No pressure..........................:)
Oh Dear(!!!)
These videos are the sort of thing that lure me into wanting a TL machine again. They're just too fun to watch.
FL's just don't compare - but our new puppy seems to enjoy watching ours (He tried licking the water - Even though the door is shut!).
I also
noticed it takes a bit to wind up to full chat on the spin, did you change out the fluid drive stuff?
willie....
sure does move that water around, doesn't he!??!!
that water is just really rolling around in that washtub!!!
LOVE IT!!!
:o)
