Work begins on the1957 Speed Queen TOL
Great video! I can get over how smooth and quiet the wash action is on this machine. No popping noise at all from the transmission, very smooth sounding. Nice job Sir!
Thank you all
for your kind words.
Ben I got it right, all that research and digging and feedback helped. I found out the Royal Purple was the same viscosity as the original just a tad thicker. So I used a mixture of half the original oil and half new RP filling to 3/4 cup.
The initial test was a little sluggish but I saw the cam bar needed a slight adjustment and performed that and whammo he took right off and spun a whole tub of water as you can see.
WOW!!!
that speed queen washer is BEAUTIFUL!!! you did an amazing job on the restoration!!! i can't wait to see "willie" filled with water, splish-splashing away as he agitates the laundry around!!!
OUTTA SIGHT job there jetcone!!!
;o)
Such wonderful progress on an arguably wonderful machine :)
At least it wasn't a very involved repair require unobtainable parts. That's a relief.
I'm with Washman on this - looking forward to some "Live Washing Action" of the machine!
puzzled..... was there a neutral spot between wash and spin......normally these jumped from the overflo agitation into spin......
am I missing something....or specific to this type of machine versus other solenoid operated machines?
otherwise...its still a beautiful machine......love that lighted console
Nope you are right Yogi
I had the "time" switch hooked up backwards too so the pause was really for the "7-2" minute setting.
Now all the switches seem to be wired proper, between the wh/red, wh/brown, wh/black, wh/blue, and white wiring it gets tight and confusing on the panel!
Always good to take pictures before you take things apart !
Beautiful job Jon as usual!
What a wonderful washer!
How is the dryer? Is is gas or electric?
This will be an awesome and fun pair! I can't get over the control panel on both. They are in beautiful shape!
Thanks for the videos on your progress!
Brent
Marvelous
Listen!
to the famous Arc-Cuate 210 moving back and forth
Watch!
As the clothes turn and churn.
Marvel!
At the kind of clean that only comes from Speed Queen.
