Yesterday's finds
When I got my first stinky bag Kirbys I wasn't prepared to try and disassemble them from saniemptors fearing I'd have an h of a time getting them to fit back on so I just filled the bathtub with lukewarm water and a small amount of laundry detergent. I put the whole thing in there and just swished it around, repeated again for a rinse and then put them out side to dry. Worked very well but still a lot of the blue color ran from the Tradition bags.
Kirby bag
I just picked up a Kirby Omega a couple of weeks ago, and I finally got to washing the bag. YIKES!! It was SO plugged that it actually held water, as if it were made of plastic!
It went thru two complete cycles in the washer, and came out just fine.
I agree though, putting the bag back on the emptor is a major pain!
This is the way we wash our....
IMHO,
The first time I used Woolite for my cloth bags was back in 1992 when I picked up my first old Hoover a model 28 with attachments at a local thrift for 5 dollars. The machine was flawless but full of dog hair and had smells to it that can only be attributed to vile waste floating in a retention pond.
My grandmother, being a normal vigiourously clean German housewife showed me the proper way to hand wash my DELICATE bag, even tho it was BADLY soiled. She soaked the item in lukewarm/cool water for about a half an hour in a washsink...agitating the item with her hands for about a minute. then dregged out the bag turned it inside out and hung it to drip dry over the tub using a plastic hangar.
She rinsed the sink and filled again with the same lukewarm/cool water and added a 1/4 cup of Woolite and dropped the bag back into the wash water. and let it soak for an hour and then giving it a brisk minute or so squeezing and agitation thru that water then dregged back out the bag and hung it over the hangar to drip.
She repeated the process with fresh rinse water until the water was clean and clear 2 rinses I remember, then a last rinse with the same amount of April fresh Downey as she used for the Woolite. Then after a GENTLE hand wringing she rolled up the bag in a large OLD bathtowel and let it sit for like five minutes or so. Then she unrolled out the bag and stretched it with her hands and placed it on top of a warm runnning dryer. for 15 minutes. Becasue it was a cool summer day she hung the bag out in the shade until it was completly dry...and the bag looked like new.
I dont rememeber if it was me,that told Jeff of this method and maybe it was or was not..but I always hand washed my old cloth bags after that day, and more importantly; back then becasue everyone either had a Maytag, Kenmore or a Whirlpool top loader..And to me and grandma, it stood to reason that if you used a fast action agitator or an agitator of any kind it would wear at old fabric like if one would have just taken a wire brush to it.
Now in 2006 my feelings on the subject have changed. IMHO if you use a gentle cycle, cold water and Woolite...I for example use my Frigidaire Gallery FL washer ...all my older cloth bags come out spanking clean. I have never had one shred or tear..and tho you may get some color runoff...that will happen whether you hand wash it or machine wash it. There's no gray area or middle ground. It's bound to happen.
I for one have washed of all things SAFELY in the cloth bag category all using my Frigidaire-
My Apex Model A3 (which has the green cloth bag w/the delicate stenciling of the Rotarex washer and the vacuum cleaner as well on it), Apex model 501 ( the blue model I got thru Jeff), Air-Way Sanitary System ( the woven cotton style outer bag with the dark green Airplanes on it..again thru Jeff)My Eureka upright model D272 witht the sideways burgandy bag with Eureka on the front panel)My Premier Commercial model 9000, and my Kirby model 505 w/ the orig bag. For these I used nothing morethan Woolite and the Cold/Cold cycle with the extra rinse..and in the final i add a (SMALL) amount of the AF (april Fresh)Downey.
If your careful and mindful as noted you can have superior results with an automatic machine as noted. And as of recent...I picked up a complete Kirby Heritage II system thru work and washed the outer bag several times without duress of any kind...except stretching that gosh da*^ed garter spring back over the Sani-Emptor.
Where some might make the mistake is using a dryer to dry them after. NEVER use a dryer unless you're using ONLY the "air" cycle to get the process moving. Or again if laid flat over the top and the heat thru the top lid to kind of give it a warming of a sort.
I have used the same machine on the Hot wash cycle to do most of my vinyl style bags UNLESS they were of the cardbord boxtop variety. Then, without discussion that's a no no and you have to hand clean those for sure or the boxtop will be ruined. Doing the methods above, you have had NO problems. My machine however only offers a warm rinse option (Hot/Cold - Warm/Warm - Warm/Cold - Cold/Cold) and after filling for the hot wash..I flip the selector over to the WARM/WARM setting to finish off the deal. It removes deep seated crud that you may not be able to get out in other methods. Again tho I use the gentle cycle.
And for those who wonder I learned how to wash out the vinyl's from Jeff as he clearly knows what he's doing and you can do it in a top loader too as he had when I visited a stainless tub Amana. Picture's dont lie...it can be done.
Anyway ALL caustic cleaners should be avoided..and if you wish NOT to use Woolite, just use an off brand from Wally-World..or another one I have tried is the Miele detergent "Persoll", which is their Woolite derivitive with the same results.
That's my seventeen cents worth
Chad
The 1020's cord change (second one in its lifetime) is complete!! Old, taped grey cord gone and replaced with a white one that looks so much better. Now I'm going to head back down to the Studio and switch the outer bag mount back to the original metal version. I know this isn't an all-original machine, but my intention was to slightly "modernize" it. One of these days a nice original 1020 is going to show up...then my current machine will have a companion.
Jeff, I'm a little embarrassed to mention (LOL), but this is currently my only Convertible. Contrary to popular belief, I am keeping my eye out for more to add to the collection...
Thanks Fred for the advice on using Brasso. I think I saw it at Bed, Bath, & Beyond...will have to pick some up next time I go to Katy. Although upon further examination, the scratches appear to have gone though the paint. Will it still work?
--Austin
Hmm..
If the scratches are very deep, and penetrate the paint, it won't work. I have some that are like that.. and I just deal with it. Another handle will be found eventually!
-Fred
PS~ Is the Constellation still all you hoped it would be? :)
Fred,
Thanks for asking. I'm still very much enjoying the 843 Constellation, and even as of now, open my closet to look at it and make sure I'm not dreaming. Again, many thanks for sending a wonderful machine; let me know if there's anything you're looking for that I could possibly find...
Austin,
You have a great and FUNCTIONAL Hoover Convertible on your hands. Looks are not always important as the following picture will show. Your Convertible with the replacement bag and type A bag looks great. They are after all supposed to CLEAN carpet. I agree with you on changing the bag ring. I do the same to mine. (I hate plastic!)Check out how beat this 1020 is (I used it to clean houses and it cleaned my house for a number of years after my parents were done with it!). It runs great but is beginning to get that bearing noise. The serial number is 10,000 something so it is early with the painted switch plate and handle bolts. The bag is a replacement with a zipper...I don't like those snaps guys!
I wash my vac bags by hand in a wash tub. I use a liquid detergent (whatever is on sale) and they come out fresh and clean. I let them soak a good while and use a scrub brush on them. I have never been brave enough to put one in the washer although I can't see why it wouldn't work. I rinse them with very hot water and hang the bag to dry so that it takes back a lot of its original shape.
--Tom
Austin,
Here is the underside of my beat up 1020. It has the Hoover replacement four brush agitator which is a bit hard on the motor. It still grooms very well. The old agitator had just run its course. This one is much quieter. I have tried it in a Decade 80, and it works much better. I just don't like the Decade 80 as well.
Check out my spring for the height adjuster...the old one went kerplooy! This was a make shift item...fits in with the whole theme of this poor old work horse! It still has a lot of life in it yet.
--Tom
Update...
The work is now done on the 1020 for the most part...all I need to do now is grease the agitator bearings and detail under the motor hood. Most of the scuffs came out and a "Mr. Clean Magic Eraser" did WONDERFULLY on the handle scratches and hood scuffs. Some areas where the paint scraped off still show of course, but it looks a lot better than before! I did put a Type C fill tube on to play with for a while, but I probably will switch back to Type A in the future...
Will try to post pictures tomorrow as I am in dire need of updating the club...
--Austin
Believe it or not Austin, I've seen and heard that old 1020 of Tom's run, for as sad as it looks it runs like a dream!
Now we need to find you a 2-position Convertible. If you like the 1020, you'll love a 2 position!!
Attached is one of my daily drivers, a souped up/hot-rodded model 36. The motor is a 4.3/4.7 amp Hi-performance deal that came from a U4103 Convertible, with a metal fan installed. I use ordinary type C bags, and have the CWP wooden brush roller installed. This thing picks up the dog hair as fast as Jack can shed it!
Tom,
Great pictures of the workhorse...another testament to Hoover quality in my opinion! After seeing machines such as this, I sometimes wonder how many Elites I'll see running past 30 years. How long have you had this machine?
Will check the serial number to verify, but my 1020 appears to be a later model, as it has a narrow handle release and 4-position height adjustment lever with grooved pads, instead of the wide, smooth levers. Or could they be replacements?
What is the "bearing noise" exactly? As young as I am, I've used quite a few metal and plastic-base Convertibles in my lifetime, and most (which were pretty beat-up as well) had a distinctive "ERRRK" sound when I started them up. When I first had my 1020, it was the first Convertible I didn't notice the sound on, believe it or not! Is this the noise you're describing?
Hi Jeff,
I love the 4-position machines. As cheesy as some of them looked (I think), the 4.8-amp plastic-body Convertibles and Decade machines could CLEAN, and had no problem whatsoever adhering to the rug. Same with the 1020 as well; you can literally feel it beating the carpet if you get down next to it.
Would a Model 589 be a 2-position machine? There's one on eBay right now that I'm watching...can't really tell what it is from the pictures. There's also a Model 68 as well, and I know that would be a 2-position, though the seller advertised that it is quite rare, which means it's probably *not* going to end at the reasonable starting price!!
--Austin
bearing noise
Austin,
Thats probably the lower motor bearing needing some grease...There are also two bearings in the agitator that need it annually too.
no and yes
Austin the 589 is 4 position, and the same vintage as the 1020.
The 68 is a 2-position, and one of the more rare models from the early 60's. 150,000 some produced.
I dunno what to say about its ending price, except it SHOULD go high, but probably won't. In the last few days we have had some rare Hoovers go for next to nothing, and two convertibles that are everyplace went for big BIG $$$$!
No logic whatsoever...
Between Tom, Fred, and myself, we'll find you a nice 2 position model. No worries!
I'm just thinking about scratches thru the paint and you know what might work as a coverup, crayons. Find a close one and rub some in and wipe off the excess, might need warming first and at least it not's going to damage things even more.
at the risk of cloying, i will add about my experiences with bags and cleaning. i have a 60s eureka upright with cloth outer bag. i think ive heard the fabric called "sateen". anyway, the fabric was obviously discolored due to age. so i wash it by hand and as i was (gently) working a stained area the fabric GAVE WAY. i started to realise the fabric was more weakened then i realised. then the printing on the bag started to fade. i did a quick rinse and can only imagine what might have happened to the fabric and print in a machine. then there was the original cloth bag on my Hoover 63. i was gently squeezing it under the water and made sure to keep an eye on how the printing would react. after only a few minutes i noticed the lettering was "softening". a quick rinse and another sigh of relief. then the vinyl bag on my Hoover 1060. i will admit the bag was already looking worn before i washed it. so i wash it and after im finished i suspected the water had weakened the vinyl/thread layers. what i like about hand washing is that you have your hands and eyes on the item being cleansed at every moment. a friend of mine was foolish enough to put a silk-screened vintage kirby bag in the washer (i dont know what cycle he used) and when it came out half the printing was gone. btw, ive washed NEWISH kirby and royal cloth bags in the machine since i had no doubt about the strength of the fabric. in my (humble?) opinion, if there are ANY signs of stress or age on a bag, vinyl or cloth, wash it in such a way that you can keep a real close eye on how it is acting. freds paintbrush technique sounds excellent. the printing can be esp fragile. if you have a cloth or vinyl bag in fresh, young condition (without fragile print), using a washing machine is quite all right. btw, i will be posting pics of my small eureka collection soon!
I grabbed these two vacs today, not exactly vintage but the price was right. The Panasonic works beautifully, a little fancier model than that Jet Flo I got a few weeks ago. What I like about it there's a small brush wheel on either side that actually brushes up against the edge, works very well. And like all the Panasonics it's not noisy. This one is slightly louder than the smaller Jet Flo but nothing like a Hoover and you can switch the electric brushroll off like on the JetFlo making it even quieter. I'll be selling this one to support my habit.. lol
pete, i like panasonics also. i dont have any, though. i wish someone would explain to me why Hoover didnt improve the dial a matic and simply sold the design. i hope whoever bought the design from Hoover paid for it because it was sure worth it. seems all hoover had to do was put the metal nozzle on a diet, strengthen the handle, improve the wheels and improve the secondary filter. the dial a matic didnt have to die so quickly. since they didnt, enter panasonic. very nice pete.
