The First Wash
Put the last few connections on and then hooked the drain hose up, set up the garden hose and plug in the power. I was not expecting much, but the door lock light came on and the water valves started an Energized, filled to the original water level this machine had, valves shut off and then the Motor turned. I was in heaven watching it, but now for the bad news, the heater isn't working. i installed a new thermostat as i cut the capillery of the old one by accident. Then came the first interim spin, i did not know that the motor would spin without a little hand, and she sure does fly, there is some power in that motor. The first rinse came, and the water level filled to the same level as the wash, just above the bottom of the door. this repeated for the final rinse, again another problem, the fabric conditioner woudn't work, so that needs looking at. The final spin went very well and not a sound throughout the cycle. So overall I rate it 8/10. Still some improvements but they can be done when i get round to it. Anyway, will upload videos soon.
