Zote soap!
gpevas
Jul 13, 2014
63
Parma Heights Ohio
I wondered if anyone has tried Zote soap? I use it in my Speed Queen wringer washer and can't believe the results. The soap gets my bed sheets and pillow cases super clean. I have oily skin and no detergent would get them clean. Zote in hot water did the trick. This Zote now comes in flake form. I still like to grate mine though. Any one try it? Gary......
I use a bar of it for pre-treating things that will be sitting for a while before washing.  It works really well.
Worth every penny of the $1.00 I spent on it.
I guess it would work best in soft, hot water? I remember a thread here awhile back about making ones own detergent with grated Zote and some other ingredients. My Mother tried this several years ago, but she has hard water and it didn't give the best results. Maybe it would work acceptable for me, as I have softened water? Thoughts?
I
also live in Ohio and would love to try some of the flakes. Where do you find them? I have used the bar by grating it before and it was great. Sure would lilke to find some flakes !!!
Jim
Zote flakes, i thought they were sold at Walmart? I know of people buying it there...
I am an occasional soap flakes user...I do my own but I also buy them ready at times...
You can also find interesting some Hispano shredded/grated soap, for washers, usually sold in dollar shops and such...
I wanted to order it from this shop based in NY state along with a couple others...but had to renounce at this time...
This is the product, wholesale supplier:
http://www.proveedorajiron.com/index.php?route=catalog/product&id=7921
The shop I was talking about is this one:
http://www.shantimaainc.us/[this post was last edited: 7/25/2014-19:47]
according to walmart, zote soap flakes is available near Parma OH in the following stores:
Walmart store #4342—Bedford
22209 Rockside Rd
Bedford, OH 44146
(216) 587-0110
13.97 miles
View map
In stock
Make This My Store
Walmart store #2362—South Euclid
1868 Warrensville Center Rd
South Euclid, OH 44121
(216) 382-1657
15.99 miles
View map
In stock
Make This My Store
Walmart store #5066—Avon
35901 Chester Rd
Avon, OH 44011
(440) 937-4750
20.21 miles
View map
In stock
Make This My Store
Walmart store #2323—Stow
3520 Hudson Dr
Stow, OH 44224
(330) 923-8232
23.14 miles
View map
In stock
Make This My Store
Walmart store #1863—Eastlake
33752 Vine St
Eastlake, OH 44095
(440) 269-8827
26.6 miles
View map
In stock
Make This My Store
Walmart store #1911—Akron
2887 S Arlington Rd
Akron, OH 44312
(330) 645-9556
31.89 miles
View map
Limited stock
Make This My Store
Walmart store #2073—Cleveland
10000 Brookpark Rd
Cleveland, OH 44130
(216) 741-7340
2.85 miles
View map
Link to product:
Soaps works surely best in hot water...they dissolves better.
If you have hard water (and I do), you will need to boost (actually reduce water hardness) it with something not to end having to use alot of it....
Also, as you have water more hard you'll need to pay more attention to the scum formation in rinsing...
For hard water:
Baking soda as for washing soda (less of it) or combination of Baking soda + borax will do the trick... even though I find baking soda better for this purpose as it easier to rinse than washing soda, you may also want to put some sorts of oxy additive along if you have really heavy soiled...
Soap requires careful rinsing anyway...
P.S
Many homemade detergents recipes you find around are often very badly balanced and actually nonsense....
[this post was last edited: 7/25/2014-20:02]
I have Zote-bought it from the new Wal-Mart near me-works pretty well-simple and a nice smell.Use the flakes.Tried the bars-Its just easier to use the flakes-no shredding required.The Wal-Mart carries both the white and pink bar Zote.The flakes are white.Yes,think both the flakes and shredded bar Zote works best in warm or hot water.Since just about all of my loads are warm or hot-this isn't a real factor.
Zote
Dose contain Optical Brighteners, so if someone's skin is sensitive to them...
STPP would be a better choice for softening the water, and if you have a TL it's better to fill the washer, then add your water softener, agitate, then add soap, agitate, then add clothes. A little STPP pre diluted in water added to the first rinse helps too.
Well,
I checked my Walmart yesterday for the Zote flakes and bars and found neither. So, I came home and got on Amazon and found both. I ordered a 4 pak of the bars and a box of the flakes. They were not all that high in price so went for it. I always use hot water in the wringer so it should disolve OK, I hope. I can't stand scum so if that happens I won't be using Zote LOL. I like the fact that there are no chemicals. I use my Maytag E as a daily driver for the most part and it seems no matter what I use in it for detergent it tarnishes. I polish it and use it once and it is tarnished again. Needless to say it is tarnished most of the time LOL. My SQ, Maytag J and N don't have that problem due to their porcelain tubs. Wish me luck. Thanks for the tip about the Norwalk Walmart Kenmoreguy. Wish I had read that tip prior to my ordering from Amazon. If it works for me I will make the trip up there and get some. Thanks again !!
Jim
Hi Jim
My E dose the same thing. More so with powdered detergents. (Powdered Ivory Snow was one of the worst one for tarnishing)
I've just had to get over it, and polish it when I'm I the mood, otherwise it is what it is :)
Don't think the soap will have an effect on the tub any worse than a powdered detergent.
The Zote.. again, a little STPP, a warm first rinse ( first being the operative word here) and it may work just fine.
Let us know
Stan
Hi Gary
And welcome to the forum.
Was hoping someone would answer your question that could do a better job than I could, but 'll try.
STPP is a abbreviation for sodium tripolyphosphate (Not to be confused with TSP) And yes it is a water softener. The advantages to STPP over other water softeners AKA Washing soda, Borax is that STPP is a non precipitating water softener, where as washing soda (sodium carbonate) and Borax (sodium borate) are precipitating water softeners.
Now day's, most powdered detergents contain a fair amount of washing soda, instead of the phosphates.
There was a time when STPP was a standered ingredient in both laundry, and automatic dishwasher detergents because of its effectiveness.
Since hard water, particularly the calcium, and magnesium found therein is detrimental to detergents and particularly to soaps, it's often necessary to find a way to soften water to allow detergent and or soap to do its job, and not be deactivated by these minerals.
Since this thread is about using a laundry "soap" rather than a detergent (remember the two are different) and since soap is more sensitive to hard water minerals, especially if there is more than seven grains waiter hardness, STPP was mentioned.
Generally speaking, if a type if laundry "soap" is used, it's almost always necessary to use some type of water softener, or builder (precipitating or non) to assist.
Others here will be able to explain this better than I did, and go further into the details.
For now I hope this helps.
OK
I am hooked on this STPP info. Where on earth do you buy it? I have never heard of it other than reading about it here. My water is hard but I have no idea how hard. I use a wringer washer only and Tide, Ariel and Oxydol powders all suds nicely. So, maybe it is not to hard. Anyhow, can someone please tell me where you buy this STPP so I can try it? Thanks !!
Jim
Yes, phosphates are surely better to use, I did not mention them as generally they're not easy to be found...
Over here especially.
Your best bet is over ebay and internet, hardwares and such..under the full name.
Sodium tripolyphosphate, or sodium triposphate.....these are the two (actually one same thing, just called differently) that best suits the detergent water softening ingredient application, even though, also trisodium phosphates finds/found application in detergents and cleanng, IIRC this last one is a stronger type.
http://en.m.wikipedia.org/wiki/Trisodium_phosphate
http://en.m.wikipedia.org/wiki/Sodium_triphosphate
Baking soda works fine if used correctly as for washing soda, but as mentioned and especially the last may get problematic if too much is used and you are not practical about, as it will give problems of precipitation build up....so the classical white streaks on darks, chalky marks and stiff laundry due to build up imprisoned in fabrics, ...classical result of crappy ( badly formulated) powder detergents, so ones which are all about soda.... And not containing, or at best, very few of the alternative *better* builders and water softeners.
If in a correct amount and in well formulated detergents these alkali do not give probs anyway.
Alternative builders and w softweners:
Powder detergents, do not contain only washing soda or baking soda for water softening function, once as Stan said they relied on phosphates that also played a cleaning function, but today have been replaced and taken out in the United states even by dishwasher products, this not because alternative ingredients are thought working better, but because phosphates have been held responsible for algae growth in rivers, lakes and such, long story, if you type stpp or phosphates in the website search box you'll surely get many info from past posts and threads, as mentioned they have been replaced partially by washing soda (sodium carbonate) and alkali in general, and partially by zeolites and carboxilates, also phosphonates (which are not related to phosphates) which are found in greater quantity and especially in the *better, top of the line detergents*...these are also the main ingredients found in laundry water softener such as Rain Drops or Calgon etc (once they were all stpp).
They will also potentially produce precipitation versus the phosphates, but not like the soda, plus they will also be more easy to be rinsed than soda.
Cheap powders tends to have more soda than the rest, or even totally exclude these other water softeners, this because policarboxilates and zeolites are more expensive than soda.
If you can get your hands on some stpp then I strongly reccomend you to use it, otherwise baking soda or alkali should be fine....as long as you do not use too much of them.
If you think it may be best, you can also try to go with some calgon.
Most baking soda brands as for the leading Arm and Hammer box it should state the various use and dosifications for cleaning, laundry, deodorization, carpet cleaning etc....and depending on your water hardness you should be able to detect which is the amount that will work for you pretty easily.
[this post was last edited: 7/30/2014-09:07]
