Washer and Dryer Cycle Times To Long?
He doesn't specify front load, traditional top load, or HE front load.
90 minutes is far too long in a tradition top load and significantly short for a front load. Not sure what the 90 minute cycle is referencing to.
His quote about detergents being quicker is also wrong, todays detergents are heavily based on enzymes, which takes longer to achieve the same results from heavily phosphated detergents that were very alkaline in the past. Oxygen bleach based detergents also require significantly longer times to wrok their magic.
There's a reason a white cycle can take 3+ hours in a front loader.
"He doesn't specify front load, traditional top load, or HE front load."
Whoops, I meant front load, traditional top load, HE top load.
my toughs pretty sure chetlaham will agree with this
My toughs on washer modern front load top load direct drive old school mechanical timer belt drive ect
its for us humans to decide 1 the amount of water use base on load size (water level) wash rinse temp cold or warm rinse if washer is before 2025 and older wash time and cycle amount of detergent this should not be control or decided by a computer say you have a typical family with 2 kids in school and you need to wash there gym clothes because they have gym tomorrow would you went to set washer to a super wash pre wash + wash followed by a 14 minute wash then send to the dryer or hang to dry or wait 1 to 2 hours letting everything being control by the washer computer water level and all and see a white shirt need to be rewash because mud stain is still showing or shirt needs to be bleach because of the auto sense washer did not put in enough water (exemple)
Agree, and, I'd say your spot on correct.
Washers don't have an accurate way of sensing how soiled clothes are, how much time it will take to remove that soil, and at what temperature and what amount of water. Even dishwashers have the same limitations in the sense that Whirlpool tech literature admits that a dishwasher with turbidity sensor will not pickup baked on soils until after the main wash has time to scrub them off. Ultimately it is up to the user to select Pots and Pans vs Normal vs Light ect.
Electronics are really about cheapening newer washers where as an older machine would handle a moderate imbalance via its suspension, a newer machine uses sensor inputs to either re-try or move forward.
everyday clothes
When I mention everyday clothes, I'm talking about sturdy cottons with a wide range of soil levels, even to the smelliest and filthiest. You need time to remove filth. I just use a normal cycle for most loads along with heavy soil on Speed Queen, which provides a deep rinse.
And then you see on Social Media like TikTok laundry tricks like laundry stripping and how gross the water is after "stripping" the clothes.
Or other people complain for residue and mold on the machines.
Hello? Learn how to wash your clothes and stop being lazy.
I see people dumping everything in one load , using ONLY the quick cycle and use "Eco Friendly" detergents which actually is pure washing soda, in COLD water. Good Luck!
I wash everything in warm (yes darks as well), extra HOT for towels and sheets. nothing damaged and everything's clean including the machine.
My TC5 takes 35 minutes. I have no choice (unless I do a pre-soak, never have), and it seems fine.
My mother in law, and my neighbors top loaders shortest cycles take about 80 - 90 minutes, and they don't have any choice. And they don't like it.
Does the SQ that Jerome uses take longer?
My dryer takes about 45-50 minutes on low. Also seems fine.
Not sure what the point of the article is.
JohnBee you & I have the exact same approach to laundry!!! I think we've had this discussion before.
William, the TC5 masnual does have the option for Heavy Soil, so don't say you have no choice!!
appnut
I meant that I don't have the choice for a longer cycle.
According to the TC5 manual, Eco, which I don't use is 27:50, with no options, 34:50 with extra rinse.
Permanent Press is 29:40, and ALL others are 32:40.
I find it's closer to 35 minutes.
Heavy soil has the pre-soak, and I did mention that.
Interesting...
I always thought that TLs washed faster than FLs, due to the former's higher water usage and agitator motions. However, my last washer (Frigidaire TL w/ agitator), had LONG cycle times; a Normal cycle lasted about 75 minutes. I think the 90-minute cycle is referencing a "heavy duty" wash.
My current GE FL has a normal cycle that lasts 55 minutes with the default settings (normal soil level, warm water, high spin speed). That's an improvement over the Frigidaire, but I still feel like wash cycles take forever with a front-loader. This is based on my past experience with the LG at my old house. Other cycles, like "towels" and "bulky bedding" take a little bit longer.
I use All Free & Clear liquid as my main detergent (poured into the SmartDispense tank), and it has given me consistently great washing results every time, regardless of temperature. I use OxiClean in a hot water cycle if laundry is really dirty, including kitchen towels (they get stained with food all the time). And, since I work in food service as a dishwasher, I recently started to "quick wash" my chef coat and aprons in hot water with a teaspoon of liquid dish soap poured into the drawer. It helps to loosen the food and grease stains before washing them with the rest of my laundry.
A Whites cycle in my GE takes about 90 minutes, largely because steam is automatically used. It is injected into the load before the washer fills with water.
A soak period before the rinse, and a longer agitation time. The charts are a bit confusing, as it only gives total time without any options.
There is this:
Heavy Soil - Fill/Agitate/Soak/spin 24:00
Others:
Wash - Fill/Agitate/Spin 17:30
I have no idea how much of that extra 6.5 minutes is soak or agitate.
In Eco you can choose extra rinse/soak, which is 27:00 soak. Never tried it. I don't use eco. In the other modes if you choose extra rinse, it does 2 full fill rinses, which seems excessive! My wife chose that once, before learning to use the machine.
Reply #15
I'm not sure why my mother in laws, and neighbors machines take so long. I know they take forever to fill, as they will stop filling, rotate, start filling again (auto balancing?). And a few other oddities, like very long pauses between wash/spin/fill cycles. My neighbor has Kenmore's with agitator, not sure who really made them, about 15 years old. I forget what the MIL uses, no agitator. She hates it though, because of the time.
We used both when our septic field needed replacement, and after those attempts just went to the laundromat, and dried at home. Much quicker. Luckily that only lasted 2-3weeks.
speed queen
The Speed Queen front load takes 42 minutes on the longest cycle, while the top loads take 38 minutes on its longest cycle. All being normal and heavy soil. I'm fine with that. On the LG and its counterpart back in Killeen, I'd just stick to the normal cycle unless clothes are extremely dirty or just plain smelly. We are talking about BO.
sorting
I sort by color, fabric type and soil level. I use the normal with heavy soil for the best level of cleanliness and an old school clean on the Speed Queen Commercial units here. When I used the LG or Kenmore Elite in Killeen, I'd use the normal cycle or whitest whites with whites.
Darks: cold water, normal cycle
Lights: warm water, normal cycle
Whites: hot water on normal cycle and whitest whites regularly if available. All with turbo wash when available as well.
Jerome, that sounds like me!
Except you sound like you could get away with a one speed motor and continuous agitation. Am I right?
For me its as follows-
Whites, Towels normal cycle hot wash.
Sheets permanent press cycle hot wash
Colored sheets permanent press cycle warm wash
Causals, medium soils, everyday cotton clothes normal cycle warm wash.
knits and non bright delicates delicate/hand-wash cycle warm wash
Bright colored delicates, fad-able delicates, wool sweaters, knitted items, silk, lingerie, delicate/hand wash cycle cold wash.
On thing I really wish I had was a warm rinse option.
Before I got my front load...and had a top load... the washer was always finished before the dryer... Now it's the opposite... the dryer is finished before the washer...but I've grown to be totally OK with that. Most of the loads I do are around an hour long... that's with heavy duty and extra rinse or whitest whites which defaults to extra rinse.. Both are around and hour and the max you could get is 1:10 if you bump up the soil level.. I have NO problem with that length of time to wash a load of clothes. I am sort of paranoid about a new washer taking longer than the times I stated above... I'm sure they're longer now than they were then...
I don't agree with this...
chetlaham
I disagree. Modern detergents have enzyme cocktails. Take Persil Advanced Clean oxi+odor for example. That stuff takes a reasonable amount of time to get the stench and stains out. When I use the ultra pacs, I use however many pods are recommended. I'll use 3 in a top load Speed Queen Commercial on the heavy soil for a full sized load. Since it offers a deep rinse anyway, I complement that with Snuggle super fresh softener.
In my LG front loader, I could get a way with using a single pod on the normal cycle. On my dad's Kenmore Elite by LG, I would typically use the normal/casual cycle on most loads. I reserve the whitest whites for just that, whites. All use accelawash. On my mom's LG Tromm, I use normal cycle for everything. The only thing that changes is the temperature. My dad's Kenmore Elite takes 26-53 minutes due to the accelawash on normal/casual, while my mom's take 55 minutes on cotton/normal. The average load would take 41 minutes in the Kenmore.
Jerome, I have often wondered if top loads would clean better with a series of soaks and agitation, where the total agitation time does not exceed 10 or 14 minutes with soaks in between increasing the cleaning power without excess wear and tear on clothing.
What do you think?
Jerome, I came up with 2 cycles, though I think they both need to go back to the drawing board.
Variant one, 3 rinses:
Variant two, two rinses:
The issue however is that I can not determine how much soak and agitation time is enough for a regular cycle, particularity the total soak allotment. Let me know your translator isn't there, I can translate the cycles to text.
[this post was last edited: 5/19/2025-05:11]
reply# 10
I completely agree. Too many people fail to realize what these so-called laundry "experts" are telling them are just bogus. It pains me to see people shove everything into a single load and expect magic miracles. Excuse me, but that's not how it works. I presort as I get ready for a shower or go to change clothes for the next day. Besides, the speed cycle is only meant for refreshing laundry. The normal cycle should be used for everyday laundry like cotton, linen, towels, shirts, sheets, jeans, and mixed loads according to my LG Tromm and Kenmore Elite models also made by LG. All I need is the normal soil level, which is a happy medium between light and heavy soils. Clothes come out just fine. I have said this a million times, and I'll say it again. Too many people these days are just too stupid to be doing laundry. They don't think to read the instructions and instead blame the machine completely.
Jerome, "everyday" clothes in that context refers to people who work office jobs and such. No grunge and heavy sweating. The Heavy Duty cycle surely isn't required, but the Quick cycle is a bit lax depending on the load size, those are intended for maximum of 2 to 3 items.
Well, the normal cycle is sufficient enough for my everyday laundry. Mondays isn't typically my laundry, but today just so happens to work out that way.
