Samsung 240 volt Vented Combo!
A true REAL combo that's vented. I could get into that!!!! For those that don't know my historym I had gas vented Lady Kenmore Combos around me as well as a Bendix Duomatic or 2 and even one Norge Combo. Wonder what load sizer is recommended to allow complete auto wash & dry without sacrificing performance to allow load to completely dry. [this post was last edited: 3/30/2025-15:35]
34 1/2” deep
Interesting, but too deep for my laundry room. Maybe Samsung will make a more shallow version in the future (who am I kidding, of course they won’t).
Ya know Jerome, you weren't around back when Bendix brought out the Duomatic. They performed very well. Bendix invented it. Whirlpool developed their own and predominantly sold them with the Lady Kenmore moniker on them and were full featured. Some models even had onboard heaters. Next door neighbor had two different models and loved them and mourned the day they were no longer produced.
Hopefully LG will come out with their own design. I am very curious as to length of cycle wash and dry. If LG, I might be interested in one or two. But then I despise top load washers whether they be agitator or wash plate.
For those unaware..
Bendix invented first washer/dryer combination unit. Sadly for everyone else as with their front loading washing machines Bendix had a lock on various patents. Anyone else with ideas in that direction (such as just plain front loading washer) had to either work around Bendix's patents, or pay up.
That didn't stop WP/Lady Kenmore, Maytag and others from coming up with combo units.
More is the pity combo units basically vanished from American laundry scene, those that knew and had them often loved such units and deeply lamented not being able to replace or otherwise find new.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?11272
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREADM.cgi?37489
Have told this story before..
At school our home economics suite of classrooms had a laundry fitted out with a combination washer/dryer unit. Having never seen such a thing (much less a front loading washer for that matter) was in awe. Home economics teachers complained about using the thing during drought periods because it was a condenser dryer that needed water to cool exhaust.
Looking back realize reasons for combo being chosen for that new school (built in 1960's) school were same as whey such units are being installed in multi-family housing in our area today, lack of access to exterior wall for venting.
I mean, yeah, that was an obvious next step - really not sure why I never thought of that.
Given they have the space for a complete heat pump system in that base machine, just chucking in a normal heater and maybe a bit larger fan isn't terribly hard to do.
Would be curious as to how well that senses.
You can't really do any conductivity checking - so it's gotta be all thermal.
“Sadly for everyone else as with their front loading washing machines Bendix had a lock on various patients. Anyone who else with ideas in that direction (such as a plain front loading washer) had to either work around Bendix’s patents or pay up”.
That’s one of the many reasons why front loaders never caught on in the 50’s and 60’s era. Not only the patents were the issue, but the lethargically slow spin speeds and ergonomics in how things were laid out, among many other factors. Companies just went to top loading designs since it wasn’t a patent or idea by a single entity or company, could have a different internal design and control panel without having a royalty to anyone, or fight in court.
Another thing too is if you were one of those to have one of the earliest automatics Bendix made in the late 1930’s, early early 1940’s, then were to trade in for a Frigidaire Unimatic or a Whirlpool in the early 1950’s, would have been more than delighted with the spin speeds and rinsing performance (slow by today’s standards, but was light years ahead around that time). Many of those people who essentially were Guinea pigs in the very early days of automatic washers then upgraded in the 1950’s were more than happy with the flexibility, washing and rinsing performance, spin speeds and probably thought something along the lines of “Why look back on when you had to bolt the machine down, items that essentially were dripping wet, things not laid out ergonomically, this is the future from here on out”.
Hold up!
There is a gas heated model?
From owners manual.
Electrical requirements
The wiring diagram is located on the plate under the control panel or rear frame.
WARNING
• Improperly connecting the equipment grounding conductor can result in a risk of electric shock. Check with a qualified electrician or serviceman if you are in doubt as to whether your Laundry Combo is properly grounded. Do not modify the plug provided with your Laundry Combo – if it doesn’t fit the outlet, have a proper outlet installed by a qualified electrician.
• To prevent unnecessary risk of fire, electrical shock, or personal injury, all wiring and grounding must be done in accordance with local codes, or in the absence of local codes, in accordance with the National Electrical Code, ANSI/NFPA No. 70-Latest Revision (for the U.S.) or the Canadian Electrical Code CSA C22.1 – Latest Revisions and local codes and ordinances. It is your responsibility to provide adequate electrical service for your Laundry Combo.
• All gas installations must be done in accordance with the national Fuel Code ANSI/Z2231 – Latest Revision (for the U.S.) or CAN/CGA – B149 Installation Codes – Latest Revision (for Canada) and local codes and ordinances.
Grounding
This Laundry Combo must be grounded. In the event of a malfunction or breakdown, the ground will reduce the risk of electrical shock by providing a path of least resistance for the electrical current.
Gas models
WARNING
• Your Laundry Combo has a cord with an equipment-grounding conductor and a grounding plug. The plug must be plugged into an appropriate outlet that is properly installed and grounded in accordance with all local codes and ordinances.
• Do not modify the plug provided with your Laundry Combo – if it doesn’t fit the outlet, have a proper outlet installed by a qualified electrician.
• Do not connect the ground wire to plastic plumbing lines, gas lines, or hot water pipes.
/quote
I know certain EU combos use the drying heater for heating (certain newer BSH models, specifically).
Don't understand why this couldn't - it wouldn't be very effective, but certainly faster than 1300W.
Or why the electric model doesn't use 240V for washing heating - it would be some design work and BOM cost, but if they already designed an entire gas version of this with all the added safety requirements that entails, running an external relay for 240V to the heater just screams cost cutting.
But yeah - LG certainly can't match that with their current combo design.
GE could, possibly, but will be 100% blindsided by this.
And at 2k$ or there abouts, it's not even THAT horrendous...
Full size combination washer dryers are making a comeback
I have Long predicted that a full-size combination. Washer dryer will become a significant player in the home laundry field, now we have four good contenders GE, Samsung LG heat pump combos and now vented Samsung 240 V electric combo.
From my reading, I don’t think there’s a gas Samsung yet they mentioned in the installation instructions about gas combos but I don’t think one exists there’s no hook up point for the gas no specification for the amount of gas burned, etc. so I doubt it’s a reality.
Bear in mind the energy guide on these combos is only for the washer. Operation does not take into account drying clothing cost
This is a hot and cold fill machine so there’s no reason for 240 V heater to boost water temperature for the extra hot wash setting 1000-1300 W is more than enough to do that job relatively quickly.
I would like to see whirlpool/Maytag come out with a combo, but unfortunately whirlpool is very conservative about introducing new products that might be troublesome because they try to maintain their top notch status for reliability in the laundry industry. When you’re the leader and laundry sales and production, you can’t afford to have a product that gives a lot of trouble it ruined your reputation for everything.
I would not look for Speed Queen to come out with a combination washer dryer either because this type of product would not be used commercially and all of their laundry appliances now are pretty much commercial machines.
John L
Reply #19
The ship sailed when Whirlpool discontinued the direct drives, even before they discontinued the direct drives since they had that stupid low water rinse which did a number on the motor coupler and transmission for sure, possibly the motor.
All Whirlpool employees, engineers, management, CEO need a good scolding to put them in their place. They’ve screwed over enough people already, committed fraud as well.
Don’t care how “good Whirlpool is”, they haven’t made anything with an ounce of quality for over 10 years. Anyone who defends Whirlpool is essentially polishing a turd.
I'll defend Whirlpool since they're still the last U.S. full line manufacturer of home appliances.
They've done a lot of things wrong, but I will still defend them because they ARE THE LAST FULL LINE U.S. APPLIANCE MAKER!
Only one machine that I bought in all the years I've been buying Whirlpool products that gave me a bad time. Just 1.
LG is not a U.S. company and neither is Samsung, Yet now all of a sudden they come at the tops of the ratings in consumer reports ? Why ? What did they really innovate ? Spray rinsing in their front loaders ? A mini washer under/over the main washer ?
As far as LG build quality being better than Whirlpool that's a laugh. The dryer bulkheads in Samsung and LG are thinner and more flexible than what Whirlpool uses.
Even Whirlpools front load wash tub, the SS feels more substantial.
Whirlpool gets a lot of hate these days but maybe people should write into them about their concerns. I for one will stick with them through thick and thin.
You don't abandon your team just because they're having a bad season.
Sean, I remember those energy star direct drives. The machines would literally fill just a few holes above the bottom of the wash basket and then proceed to agitate on high. The greatest damage was done to people's clothing. Whirlpool could have simply added a few spray rinses where the rinse increments would be with the cycle labelled as normal eco "do not use fabric softener" just as Speed Queen did. Nobody would have noticed. Whirlpool has access to timers that can perform an identical sub-interval sequence across several increments low cost. Instead they choose the more expensive, complex method of stretching and tearing customer clothing while leaving detergent all over them. Its like these companies are wittingly trying to get a rise out of people just so they'll blindly accept FL washers.
Whirlpool officially came to and when they ceased production of their direct drives.
Whirlpool should have not discontinued the direct drives. It was the end of an era, the last good yet economical top-loader ever produced stripped from the market. Everybody loved their DDs. They should and could have re-tooled keeping the DD lineup in production for another 30 years. With cool washing and spray rinsing energy regulations would have been satisfied as well. Taking away DDs left consumers with either buying short lived failure prone junk or having to spend near $1,500 on a Speed Queen that does the exact same thing as direct drive does that costs half as much to build. There are no longer any middle of the road, level headed, common sense offerings. Consumers only have extremes to choose from.
I didn't like them. The ones I used on the dorms were Maytag Commercial Laundry. The water level at so-called large load size was looking more like a medium water level. That was so stupid! I was either forced to do smaller loads or go to the laundromat. On top of that, they never did a spray rinse. This is so stupid! Pat, I feel your pain.
I used to really like Whirlpool, nowadays not so much. I feel like it's just another company that doesn't make them like the used to anymore. Even the Maytag Commercial top loader that despite they've added a water selector knob unlike it's predecessor, apparently I've discovered online they have even more problems with the water levels. In addition my brother's Maytag top loader bit the dust and it wasn't even five years old. My LG washer is still going and it's older than my brother's Maytag. My point though that just because Whirlpool may be assembled here doesn't mean I'd buy one today if my Korean made LG cleans better and/or lasts longer, in fact the best washer I've used before wasn't made here. And as much as I love my Whirlpool built KitchenAid dishwasher and would love to get another KitchenAid, I still have my eyes on Bosch because that's what my appliance technician recommended. In fact that's how I got my LG washer in the first place was because of him. Whatever is the best regardless where it's made at, that's what I'd want to have. Now as for Whirlpool being the last full US manufacturer today, I'd say only 80% of that is true. If you're not counting the commercial models, all of the consumer microwaves are being made elsewhere. And when they were back to selling central vacs, they were also made elsewhere.
Not my cup of tea. My sister in law has a GE Profile. 2 years old. Motor died 2 months ago. Figures because it does double duty. I don't know if it's vented,
Quicker drying times is a given, reliability however is questionable. Although for me this will be a low use machine, however I will probably use the dryer more often I suspect.
Reliability may be questionable with newer Samsung units, but definitely quicker drying times.
Heat pump may be more efficient, but will need a tear down to keep the evaporator coil clean. Though a good majority of us here in the club are mechanically savvy, heat pump dryers are a royal pain to clean and service compare to a traditionally vented dryer.
