Double-Duty Super-Surgilator – 16mm Film
One aspect that wasn't touched on is fabric gentleness. I recall a thread where someone mentioned that, in their experience, the Whirlpool Surgilator provided the best cleaning performance among the automatics they’d used—but it was also the harshest on fabrics. Interestingly, Consumer Reports found that the only single-speed machine to damage delicate curtains was a Maytag.
So, what’s considered the best overall agitator for a Whirlpool/Kenmore belt-drive washer? The Surgilator? Dual Action? Or one of the others? I have the PentaSwirl in my Lady Kenmore, and it seems to strike a good balance between cleaning power and fabric care—though it does struggle a bit more with overloads compared to some of the other designs.
I think I have that PentaSwirl in my Kenmore portable machine.
That's the one with the agitator dogs and corkscrew gizmo, right?
I replaced the dogs a while back, easy job.
It is advertising after all. Once you know the weak and strong spots of the machines you're dealing with you can use that to obtain any result you want, and to prove any point you want to prove.
Personally, IMO, the agitator in the film shown here pales in comparison to the dual action agitator.
No. This is Penta Swirl. It was used only on 18 lb classic belt-drive machines, typically higher-level models such as the 800 and Lady Kenmore. There was also a Penta Vane used on lower-end 18 lb models.
    22.7 KB
    18.9 KB
    19.3 KB
I honestly prefer the Super Surgilator and DDSS over the Kenmore agitators. The Super Surgilator seems to work quite well, washed a pillowcase that appeared to be cleaned but when I went to move the sheets over to the dryer, was amazed on how clean it came out.
The standard Bakelite Surgilator works well too, but is more persnickety with how the machine is loaded. Roll over with the standard Surgilator seems to be on par with a Maytag PowerFin on larger loads.
I can agree with Marky Mark about the Penta Swirl. I personally think it's a great agitator and I like it even more than the Double Duty which is also a great performer. Huge loads do hinder it's roll over some but that is true for most agitators. It's very effective in sloshing the clothes around the tub. I have plenty of videos with all different size loads.
When my neighbor V. replaced her 1972 Kenmore 800 washer in 1985, she didn't like the Dual-Action agitator in the new Kenmore. A Super Surgilator was then installed, and she was satisfied with the machine after that.
Isn't it true that Whirlpool wanted more waterflow when they went to the direct drive?
IDK. There certainly is more continuous controlled rollover and not as much splash with the DD, and not as much lateral movement either compared to a belt drive. The BD Penta Swirl for example can get the load to slosh and splash and rock the water. It can get a little tempest going on in that tub.The WP/KM DD's don't really do that by nature of shorter faster agitation strokes.
Hardly Chet. If you noticed, Kenmore agitators mostly had their vanes on the bottom. Whirlpool used that Surgilator throughout the belt drive run and made modifications to it over the years to make it even more effective. By the time the Double Duty came out in 1978 it smoked the DAA and was about as perfected as that agitator got. Would love to see some wash action comparison tests side by side. Whirlpool didn't need a cork screw and quite frankly neither did Kenmore. The Penta Swirl and vane were both fine agitators in their own right.
Hardly Chet. If you noticed, Kenmore agitators mostly had their vanes on the bottom. Whirlpool used that Surgilator throughout the belt drive run and made modifications to it over the years to make it even more effective. By the time the Double Duty came out in 1978 it smoked the DAA and was about as perfected as that agitator got. Would love to see some comparison tests side by side. Whirlpool didn't need a cork screw and quite frankly neither did Kenmore. The Penta Swirl and vane were both fine agitators in their own right.
I'm curious about how it handled tough ground-in dirt in work and play clothes compared to GE and Maytag.
What I mean is that Whirlpool had more splash in the belt drive compared to the direct drive which used waterflow. In other words, a wall of water flowing through the clothes.
Load size
Mark, you’re absolutely correct if they’ve done half the load in the Maytag or 2/3 in the GE it would’ve easily cleaned the load. The purpose of the demonstration was to show how much really dirty laundry the whirlpool could wash.
Keep in mind that this demonstration was done with the full 26 gallon tub super capacity whirlpool the GE was never more than about 25 gallons and a lot more of that stayed in the outer tubAnd smaller tub of course the Maytag only ever got up to 19 gallons. Which would’ve actually given the Maytag and the GE a slight advantage because of a higher detergent concentration, they put the same one cup of detergent and all three machines.
That's because direct-drive agitators typically don't have significant fins above the water line like the Surgilators to generate splashing. The lower fins on the Surgilators provided equivalent swishing and turnover in the nether area of the basket as the DDs. Seems clear you've never used a belt-drive Surgilator.
