Hello Bill, the Dry Cleaner
Back in the heyday of Aworg, Greg Gansky1 would treat us on holidays like Memorial Day, the Fourth, Labor day, and randomly as the spirit moved him, to gigantic threads of scans from his vintage Sears Catalogs. It took many of us back to our childhood days when we devoured every word and dreamed about the pictures. One time Greg did a scan of a spray rinsing wringer, and I nearly lost my feces. After the excitement came so many questions: How does the water get into the wringer? Wouldn't the rinse water flow back into the wash water? Do you have to keep the pump on, lest the rinsage overflow the tub? Etcetera.
Then years later, something appeared in the ephemera and it was breath-taking. The Visimatic Spray Rinsing Wringer is the most complex and highly engineered wringer in history. It attaches to the water supply by way of a standard inlet hose leading to a valve on the wringer head. A copper tube, with multiple openings travels across the width of the wringer, saturating the soapy laundry before it hits the rollers. Think about the way a 1-18 sprays a load. Next, the sprayed water falls into a much larger than usual drain tray.
AND THEN--now, hold on to your party hats!--the water exits via a short hose into the sink, diverted from the wash tub where wrung wash water usually goes. How Brilliant. It may have been a bit cumbersome, but this is only a guess, to move the wringer around with the hose attached, and thus not a crowd pleaser.
Another memory from the ephemera is that it also had a valve switch that would allow you to FILL or RINSE, and the the volume of the water flow was adjustable. Dying some day to see that fill flume.* And, the crowd be damned, there is nothing I wouldn't do, give, or pay to have this cumbersome engineering miracle some day.
* Could be confusing the fill/rinse option with the Apex version of this wringer.
PS: If I find my misplaced ephemera, will return with more info.
Good Day,
Michael, MickeyD, named not after Mc Donald's but in honor of my adored Aunt Mickey (Lenore) who let me play with her Easy Spindrer.
