S shottims New member Joined Jul 24, 2020 Messages 4 Location Indianapolis Oct 20, 2020 #1 New compressor installed. What color wires connects to the hot gas valve? and how do I check if the defrost control is working?
S shottims New member Joined Jul 24, 2020 Messages 4 Location Indianapolis Oct 22, 2020 #2 Hot gas valve and timer test? I'm trying to figure out how to test if the new hot gas valve and timer are working. Does anyone know how to test these devices?
C carolinacat Well-known member Joined Dec 29, 2013 Messages 102 Location north carolina Nov 15, 2020 #3 The timer should be in the freezer you can manually turn it till it clicks which on mine is the start of the defrost cycle
C carolinacat Well-known member Joined Dec 29, 2013 Messages 102 Location north carolina Nov 15, 2020 #4 Probably should add mine is a bottom pull our drawer freezer
combo52 Well-known member Platinum Member Joined Apr 4, 2008 Messages 17,520 Location 50 Year Repair Tech Beltsville,Md Dec 4, 2020 #5 Testing a GE Hot Gas Defrost refrigerator You could also just use a test cord with a 120 volts applied to the defrost coil while the refrigerator is running in a cooling mode to see how well it works, but I would try advancing the timer first. John L.
