1964 Multimatic Video
What a classy piece of engineering.
I think I'm in love. The agitator has always reminded me of the Gemini space capsule. I wonder if that helped link the product with the subliminal "Space Age" message of the time.
1964
I have a Multimatic just like the two in the videos. Mine fills, the timer advances, spins, drains just fine. The one thing that it does do that it shouldn't is that the tub turns as it washes or rinses.
I don't have the knowledge to fix that, whatever the problem is. It sure would be nice to be able to use the Frigidaire.
Gary, I remember you posted about this problem of yours some time ago. Mine needed some work too as the mechanism wouldn't even turn. I replaced a few parts in it but when I reassembled it, it did like yours, I disassembled it again the same day and it was just a part that I didn't assemble correctly (I didn't push it far enough inside the mechanism). Since yours hasn't been dissasembled, I suspect it has a different problem that causes the tub to turn when agitating. Does it just turn slowly or it turns fast enough to spin the water out if you let it go? It could be broken torque spring in the transmission.
Hi Greg,
I actually rescued the pair (this and the matching gas dryer) from the scrap area of a local appliance shop many yaers ago. With Ben's help we changed the trans oil, installed new belts and I recall making a new gasket for the waterpump. It likely would have worked fine as-is but I figured now was the time.
The machine is surprisingly quiet, but you'll note the cone is a little loud- that's because it has a couple broken alignment teeth and 'squawks' just a bit. Otherwise it purrs like a kitten! -C
Well, if you could find parts for it, I'd suspect a broken torque spring but it could be something else...
You have the service manual?
KUDOS! My bow to Cory (cadman)
Apart from that very nice looking machine: Your video clip must have been some major editing work.
The transitions, cutting several cameras into one consistent clip, wow.
We are no newbie to the biz, are we? ;-)
I know what a tedious piece of work / weekend kill this can be.
Just great. This is how youtube should be, heads up, dear videographers! And not some shaky, yelling (warbled pictures) "scream movie" wannabe "cool dude/ hey man" crap.
Thanks Joe, your comments are much appreciated! Truth be told, I use to mess around with video quite a bit years ago, but it's been at least a decade since I've picked up the camera...just got busy with other things : )
I hope to start weekly uploads of all sorts of odd and interesting equipment around here, at least while it's 10 below outside. -C
How fast is the spin speed
I know on the Rollermatic machines, that the spin speed is 1000 rpm. What is the spin speed on the multimatic's ?
Spin speeds
Depending of the year and model, the spin speed of the domestic Multimatic machines varies between 700 and 850 RPM.
 The 1963-64 models with the 12 pounds tubs have 710 RPM speed while the earlier models with the 9 pounds tub either have 700 or 850 RPM spin speed.  My 1960 Deluxe has 700 RPM spin according to the Tech Talk manual. The "Rapidry" models had 850 RPM spin until they stopped to offer the 9 pounds tubs.
The newer coin-operated/commercial Multimatic machines like 1966 Robert used to have had 1000 RPM spin to match with the new Rollermatic Rapidry models.
Here's a video of my 1960 spinning:
Early 60s Frigidaire Multi-Matic Washers
Yes indeed Great Videos Cory.
Hi Phil, My 1962 WCI-62 washer still has the speed shift to the faster 850 RPM spin speed, apparently they discontinued the faster spin mid year.
My question was there really difference in actual tub capacity between 1961 and 1964 or did FD like so many other washer builders just claim that their washers could wash a bigger load, I never noticed any difference.
