Laundromat Last Night
mrb627
Sep 12, 2001
5,115
Buford, GA
I was at the local Laundromat last night drying three loads of clothes. A couple of dudes came in with a hamper and stuffed its contents into a Huebsch Triple Loader. The machine was just over half full. The put their $5.50 in quarters in and selected a Normal Warm cycle. The countdown timer lit up with 18 minutes as the total cycle time. I was shocked that for 5.50 all you got was 18 minutes start to finish. The machine began its thing. At 14 minutes, the add bleach light came on and the machine began beeping. At 12 minutes, pump out. ( yeah, 6 min wash) No spin. Fill for rinse. Rinsed twice without spinning a bit. At 6 minutes, final spin kicked in.
I am still in shock. I will need to find another wash-o-mat and see what their machines do. I think there is a Maytag equipped shop a little further away. The balance of my laundry will be dried there.
I'll report my findings tomorrow.
Malcolm
WOW. I remeber the Wascomats used to be:
Pre-wash
Wash
Rinse
Rinse
Rinse
Spin
There were interims spins as well.
At $5.50 per load one could pay off a washer of their own (charged to a credit card) rather quickly.
The 50 pound (23 KG) washer was $4.50 25 years ago.
The cycle programs and sequences on the newer machines can be totally reprogrammed. Parameters such as cycle time, rinses, etc are up to the programmer. The older Wascomat Gen 3, 4, and 5 (non Emerald series models) were harder to customize because of mechanical timers, contactors, etc. The cost to run a laundromat are quite high. You also have to remember that depending on the load capacity, those machines start in the area of $5,000 per machine new. So you have high costs for the machines, high costs for utilities, equipment repair costs are higher as well. It does not surprise me of the owner of a laundromat has to pay in the upward range of $1,000 to have a repairman replace the main bearings in a small capacity commercial FL machine. As time goes (years) the cost to run a laundromat get higher. So, I can understand why the vend prices are so high and the cycle programs are so short. Oh, as long as parts for commercial FL machines are in good supply, they can/are totally rebuilt. In my area I see a lot of laundromats with the Newer Dexter Throughbred T-600,T-300, T-400, and T-900 models. No SQ's, never seen any Ipso's or Maytag/Primus for that matter. There are still 2 laundromats out of the 6 laundromats in a 25 mile radius that have the older Wascomat Gen 4, and Gen 5 (non ES)machines. One of the 2 laundromat has only 2 Wasco's and the other one used to have all 5 rows of Wascos. Now they have only 2 rows. I'm trying to get on the owners good list to get one of those W184 50LB. machines from him when he replaces the remaining 2 rows. Also the newer machines are a little more efficient on power with VFD's running the drive motors. Most newer machines can run on both 3phase and 1phase power. In the past Wascomat and other brands of machines would require 3phase service. There were 1phase machines for the same models, however they are more complex, and more expensive to repair. As costs increase for operating Laundromats, you will see more of the customizable machines. Thinking business-wise, it is not cost effective to have machines that can't be customized and are considered less efficient. The owner can "adjust" parameters to off-set costs. I think since the economy is in the state that it is, you will see more of the newer ELECTRONIC customizable machines. Currently I have Wascomat W73(Gen3), and Primus W10 machines. If you have the means to get one of these machines, and can supply it what it needs, I encourage you all to get one. These older commercial FL machines are disappearing kinda fast.
The 50 lb at the nice lady's laundromat is $5. I thought that was expensive...it runs about 40 minutes. Guess it's a bargain! It's labeled a "Speed Queen" but looks identical to the 30 lb Unimacs sitting right next to it.
Wascomats!
I just loved those wascomats - used enough water and washed well. I wished the wash phase was longer - but clothes always came out clean. I wish they would make them for home use.
Peter
Malcom,
Where is this laundromat? Email me.
In the South, we are still averaging .10/lb. If that was a triple, it should be about $3.00.
The story I got years ago was that an exec from Wasco jumped ship for Unimac (then making SQ commercial washers) and revamped the coin op cycle to mimic that of Wasco. Depending on the model and the options available to the owner, they can drop the prewash and a rinse, but cannot extend the wash time. Sounds like this owner decided to do this in the middle of the drought and/or their water authority raised water/sewer rates. That they did this AND raised prices so exorbantly sounds to me like this owner is either greedy or getting ready to go under or both.
The price is a bit high for a triple. Here at our laundromats SQ toploaders are $2.00, Dexter triples are $3.75 and Dexter Maxi (40#) are $5.00 Dryers are 5 minutes per quarter. The front loader cycle us around 25 minutes and spins after the wash and each rinse.
We have Maytag triple wash machines down the road from us. They cost 4 bucks per load...but take about 40 minutes to complete the cycle. But these machines are quite old, and honestly I think the newer consumer front loaders are quite a bit bigger.
Aaron
My last quilt washing in Millington Tn, i used a new wascomat, had the "electrolux" emblem on it. had the same dial with prewash,w,rsrsrs. It was $4.25 to operate. but was similar to the older cycle i remembered in older Wascomats. alr2903
Machine Swap
Rather than going to the laundromat in the morning to finish laundry, I decided to go ahead and swap out the SQ dryer for the 26 year old Maytag. Thank goodness I kept it. I really didn't want to have to move the SQ dryer, if I could help it. But, I decided it would be move convenient in the long run since I'm not sure when the SQ will be repaired.
Malcolm
Malcolm
The new Huebsch front loaders here do the same thing. The first time I used one it showed a 14 minute total cycle, I was like ok, what a rip off. However for an extra 50 cents you can get an extra wash and extra rinse. Or 25 cents for each one. With the extra added cycles they seem to do a good job. Luckily the laundromat here that has them has a special every tuesday and thursday $2.00 for the standard cycle. $3.00 any other day. But, this is why I prefer top loaders over front loaders unless I absolutely need to use one.
We have the Wascomat Junior and Wascomat Senior washers in our local coin op. They both cost $3.50 per load. The old Maytag top loaders are $1.75 per load.
They haven't messed up the cycles on our Wascomat machines, each cycle takes abou 48 minutes with generous rinses between the wash cycles.
The only thing we have to watch out for is the oversudsing, overloading Mamacitas. The Chinese people who run the laundry keep a watchful eye on things. They always have at least one attendant on hand. It operates 8am-8pm only. He usually walks around with a jug of cheap fabric softener. If he determines that you have oversudsed your machine, he pours a bunch of fabric softener inside your machine!
They recently repainted the place and switched from CRT televisions to flat screens, which are always tuned to CNN.
Huebsch
Is it posted somewhere in your laundromat or on the machine that you can add more coins for extended cycles? The machines at my local place don't have any indication that more money equals better service.
Malcolm
FSNazi - That is funny.
rip-off
Some places charge for hot water in the machines. Have a place in town the has a sign of the wall the brags 140F hottest water in town. Only problem is they have the new Whirlpool TL that meet the 2007 standards,so the hot setting is barley warm. If I am paying $1.50 for 3/4 load, I want hot water. I never went back.
New SQ frontloaders at my laundromat charge 2.00 for a lightly-soiled load and if you select heavier soil, then you are charged 25¢ additional. So, medium soil is $2.25 and heavy soil is $2.50 - resulting in 5 - 10 minutes of additional wash time.
At least...
the modern machines give you the flexibility to better customize the cycle for your personal needs.
Malcolm
Malcolm.....
It has the options right on the machine underneath the cycle buttons. If you push extra wash it adds 25 cents, and if you add an extra rinse it adds another 25. You can use any combo of the 2 that you want.
