14 minute wash
Hey Peteski-----you are correct, the dial has 10-8-6-4-2 printed, but it's got notches and detents for the 12 and 14 for sure. Personally, I don't think ANYTHING needs more than 10 minutes. If it needs more, stop it after 5 and soak for a half hour, then turn it back on.
This thing just cycles perfectly! My 1960 WP and 1974 Kenmore do the neutral drain far too long, this one kicks in the spin within about 15 seconds of hearing the pump suck air, just great. And somehow, while I've never been entirley impressed with the WP/Kenmore 4 sprays instead of GE/Tag/Norge/1-18 having those 1.5 or 2 minute plentiful spray rinses, this one gets more suds out than either the 60 or 74 models, who knows? No need for extra rinse or extra spray. Maybe it's because it's pre-set on many temp choices here to give a warm rinse, so both solenoids are open and more water than the 74 model. Then when spray is done, I switch to a cold rinse choice for the fill.
My 1960 Whirlpool Imperial Mark VII is impressive but the 10 pushbuttons means there's no dial to watch so you know exactly where in each cycle you are. And the 1960 timer has given me intermittent trouble as far as powering the 3rd solenoid on the inlet valve, often that mix valve doesn't work and MEDIUM means HOT, warm rinse means cold, etc, then it's fine for two months. Frankly, if you push the timer knob to the left, it works correctly but I've had it apart too many delicate times to try fixing it for a livable error. But this 1959 3 solenoid, with the clear choices on the temp switch as opposed to the "pre-chosen" pushbutton one, and the exact ability to start/stop anywhere on the dial, it's just perfect operation.
I like the 1960's visible Magic Mix filter where you can add the soap and watch the water, but the lint filter here seem to get more lint, so it's pretty darn cool too. I agree it's almost entirely unnecesary in modern machines and modern tumble-dried laundry, but lint filters are fun as hell. I have never complained that it's an ugly job to clean them.
I installed a 1950 3 vane, 3 stub agitator for about 5 loads, couldn't tell any difference from the Surgilator. But the Surgilator has a shiny chrome top, so I went back to it. It sparkles, you understand.
