'63 Frigidaire Imperial thread
Water bellows back in place. Snap ring pliers laying in tub really help make this a much simpler job in removing and replacing the snap rings on both bellows. There is a smaller set of these pliers (not shown) for the oil bellows.
Sub top and water injector back in place.
"But Patrick, I still see rust on the top" --- Yes you do but I am trying a new product which was a bit cheaper than POR-15 to coat this rust and see how it holds up. It is a clear spray (although it comes in colors too) made by Rust-Oleum. It looks wet after you coat everything but 2 years later I opened it up to take a look and rust is still frozen with no new rusting. Later if it starts to rust I will sand it down and coat with POR-15. I actually ran out of POR and this is what led to doing it this way. Seems to be working and was a lot cheaper.
I did have a problem with a leaky pump but unfortunately I never took pictures of the repair process. I had already repaired a Unimatic pump that leaked at the carbon seal so with that experience I was able to fix this one as well with no new parts except some cork gasket material bought at the auto parts store and I cut it to fit. It worked perfectly.
Here are the machines in their permanent place. Since the dryer is gas they must stay right here next to the furnace where the gas connection is located.
Nice looking machines!
Is that a new diaphragm? Where did you get the new diaphragm and what did you do with the old one?
Don't want to be a killjoy, but that hard plastic agitator cap invariably lost one of the tabs over the years and then the cap does not latch closed. The less opening the better, IYKWIM.
Did you do anything to modify the tub outlet flange?
Thanks
These are just gorgeous Patrick!  Glad you took pictures of the progression.  I remember how hard all the scrubbing was on your hands, good thing you use Palmolive.  As Madge always said, it's MORE than just mild.  Tell me one thing though, why didn't you bypass the lid switch?  I tried and tried to convince you but you wouldn't.  Every time I'm there we have to put that pesky screwdriver in the hole to watch it, then I have to cleverly edit it out of the video afterward.
Wow, great work Patrick, I'm totally impressed. That washer will last another 20 years now at least.
Thanks for the great restoration thread!
Fantastic
Patrick, you continue to amaze me! Another great restoration. Such quality work and documented so well. You make it look easier than it is.
Thanks for posting and sharing.
John
Your questions answered:
PhilR - from one Frigidaire enthusiast to another, thank you very much!
Joe - Thanks. I don't know why I didn't take pictures of the mechanism. I had that machine on its side enough times! I should get some one of these days when I inspect to make sure all is well underneath.
TomTurbo - I did get a new diaphragm. Funny story is that I found it on ebay and the seller had no idea what it was. I saved the old one just in case but it eventually would have fallen apart if used. As for the agitator cap, I know what you mean and just leave it on all the time. No, I didn't alter the outer tub drain. I will check it every so often if I think something is up now that I'm a pro at pulling the wash tub out. I did coat it extra well with POR.
Eugene - I'm glad you liked and thank you very much.
Brian - Thanks! These machines definitely had The Jetson's look to them.
Eddy - Now you know I go for originality in function when restoring a machine! Maybe I will consider putting a hidden bypass switch just for you.
Stan - You are welcome. I enjoy sharing the pictures once the work is done.
Jeff - Thank You. I appreciate your compliments.
Robert - As always, you're welcome! Your labor of love with this website has been my best inspiration. As for another 20 years, let's just hope the belts last!
John - Thank you. The pictures make things look easy and it seems easier now that it'a all done. But when I started on this I had never done anything like this before so it was all a huge learning experience. I get more confident with each machine I work on.
Peteski - Can you say "YAY for GM Frigidaire"! I knew you would enjoy.
David - I can only hope these will outlast any modern machine. I take great care when using them to help in that endeavor! Thank you.
Louis - I will leave these to you in my will. Now how to get them across the pond???
David -
I love your sense of humor! Thanks for the compliments, too. You know, you really should start a collection. You can just park those pesky autos in the driveway and you'll have plenty of room!
Patrick
Collection
The convertible BD Lady K that Jon had now lives with me (if you remember it). Technically I think that means I have a collection, or at least a junior collection. Lol Still trying to figure out where/how I can squeeze in extra machines. There have been some good machines on CL lately and one of these days the temptation will be too great to resist!
David -
Glad you have that LK machine from Jon. That was a fun one to play with and has a real fast spin. So yes, you have officially begun a collection. CL and estate sales can be very addicting, too.
Hope you have a great Easter Sunday.
Patrick
