70's Kenmore Suds model
akronman
Jul 20, 2010
2,258
Akron/Cleveland Ohio
It's mine and sitting in my garage, out of the rain. The seller said it's been in use in the house since the 70's, his new house has visible laundry near the kitchen and his wife demanded new. This was in use until 2 weeks ago!
Model 110.73570100, serial number C52803750. So what's the date of birth?
more
Here's the original Craigslist pic, it turns out the messy timer area is just soap/crap, wipes right off. And the water temp button broke off when the seller moved it from the basement, I'll find a new one.
console
Please excuse my rotten photo skills-----You can see SUDS at the 6 o'clock osition, no other buttons for suds. The seller said they never used suds, just stuck both hoses down the drainline. I guess it automatically saves suds every normal cycle???? Then if you do want them returned, you make sure you already plugged one basin and then set the dial here?
The next pic will show the soak knob, helps explain the timer? All of this is while it sits in my garage, no hookups out there. And obviously I haven't wiped a thing clean
That's a really nice model. And thank God for trendy wives who just have to have something new!
Mark, you've been around for a while, so you know the first 2 digits after the 110. are always the year of production for a Kenmore--right?
So it's a 1973 edition.
As for month and date, I don't know how to do that yet. Maybe this time I'll pay attention and learn how to do the month, day and location--all of which are hidden in the code.
No matter that it's not a Suds; you'll make her recycle anyway.
Agitator
Dark gold Penta-Vane, of which I've heard tell. I'm getting ahead of my self here, but wouldn't this extra capacity mid 70's KM be eligible for their early double-action agitator? Some machines I keep pristine, some I swap around to see all the options. And WOW is the tub deeper than my 1960 Whirlpool, huge!
How did the same 29" cabinet fit this larger tub? Did they just lengthen the suspension rods, drop the motor and tranny closer to the floor?
Mickey
Mickey--reread it buddy, it IS A SUDS MODEL!!!!!!
I know the 73 is a signifier, but at times they continued a model into th next year, I have a 63 model dryer from Kenmore with an April 64 build, it was a popular model so they just kept on.
This one looks pretty easy to get up and running, surface rust near the base, to be expected, and the owners never wiped down a damn thing, oh well.
You are right, I'd have found a dry agitate timer spot and sucked suds anyhows, but this is a suds model from the factory!
I canb't wait to get her downstairs and check out all the soak only,. soak to wash, sudsing, etc, holy cow.
underneath
70's era braces for the transmission, a capacitor for the motor, the suds valve installed along the back, all stuff my 60 WP doesn't have.
But where is the Magic Filter?
To me, for an Ohio basement for 40 years, the base is about what I expected.
I see that, Mark. What a fat toady I am. LOLOLOL.
Go so lost thinking about such a whole club-favored machine and the number stuff, I forgot the thread title.
Even as I wrote the sentence, there was a little ping in my brain, but I ignored it.
I love it.
All those features make it seem like a Lady K. And a REAL Suds. I'm bubbling over white with envy.
Serial = 28th week of 1975.
The gizmo in #9 is a detergent dispenser, which is required as part of the automatic soak-to-wash function.  It's apparently missing -- I've never seen one but as I understand, a removable reservoir cup with a flap that opens on the bottom sits atop the block. A solenoid-activated pin kicks out of the hole in the rim to open the flap so the detergent falls out.
The answers to your suds questions are Yes and Yes.
Also noticed the Suds is located just before the soak without an OFF position suggesting that it goes right from Suds to Soak. Haven't seen this maneuver before. So cool, and so flexible. Think of all you could do with a really dirty load. Return the suds, go right to soak & wash. Then use that new liquor for the next load.
I have never seen this before, Mark; in fact, when ya think about it, Suds models in machines of this period don't show up all that often.
I just studied the control panel more carefully. There is a longer white line after the suds and before the 22. Maybe there just wasn't any room for OFF, and it does indeed shut off after the return.
But then again, maybe not. Now I'm really excited to see what it does when you get 'er rollin.
Mark -
So glad you got this. I guess I spurred two menbers in one weekend to grab a machine off Craigslist, almost like a washer pusher, lol.
Let's see, in no sort of order, here's what I can tell you:
1) Its a 1975 model. After 1973, the model numbers read differently than they did 1973 and earlier. To the right of the decimal, the first digit is the decade. So, 1970s. Second digit is the application: 1= 24-inch standard, 2= 29-inch standard, 3= 29-inch suds, 4= compact, and 5= 24-inch suds. Thus your machine is a 29-inch suds model, which we already knew. The 5 is the year digit. The 701 is the series, and the 00 is the engineering revision. There were very few 1975 models (like four or so only) and most didn't get any revisions before the 76s came out.
2) The soak selector works as follows: select soak only and the machine will stop after the drain and spin after the pre-wash segment. Select Soak and wash, and the machine will continue on into the Normal cycle.
3) Do you need just a knob for the temp, or the whole switch? I have boo-coos of knobs, one can have your name on it, just ask. If a switch, the same replacement switch works in machines all the way back to 1960 or so. I can dig up the part number if you need it, but if you'd like used, there are lots out there, I probably have one of those as well.
4) The self-cleaning filter is the tub-mounted variety, probably the best overall of the SC filters on Kenmores. Maybe John knows better but these seemed very effective and not all that troublesome. They needed a minimum of plumbing as well as compared to others.
5) That fixture in the left upper corner is for the powdered detergent dispenser. They are almost never included with a machine.
6) Tread lightly around the bleach and softener bezel - they can be brittle and then don't secure themselves once the snap clips fail.
7) These big tubs fit in the machine just as you said, they deepened the tub and thus the suspension rods, and dropped the entire baseplate and everything under it closer to the floor. BUT, they also made the tub wider. If you look at the cabinet, there are some half-moon shaped indentations in the front and sides of the cabinet to allow the tub to fit into the cabinet.
8) A Dual-Action agitator will fit with no issue in your machine. Sears tried to sell them in their catalogs for a number of years in fact for retrofit. Just make sure you have one with the large capacity auger. The standard version uses the same base agitator but a shorter auger. There is little to no chance you'd find a standard version (quite uncommon), but you never know.
Cool machine Mark - I never saw one of these in a suds model, but that's the midwest for you. Your machine may tie one of mine for the nastiest Kenmore of the week prize. Mine I rescued from a filthy installation in 2010. I wrote a whole thread about how disgusting it was. People actually expect these machines to clean for them? Really? Try keeping it clean then!!
Can't wait to see how you come to like this machine. Congratulations to you AND the machine, I think it landed softly in new digs.
Gordon[this post was last edited: 4/8/2014-00:19]
Thanks
to you all for the info!!!
Dadoes---SearsParts diagrams call it an engine???? thanks for the explanation, yes a soak-to-wash cycle would need more detergent. Does anyone even have a picture of such a cup?
Gordon--#3--I have the knob, I found a new switch for $14 on Ebay, already ordered it, thanks.
#4Tubmounted self-clean filter----not sure what you mean. So it ain't the magic filter I've seen in late 60's models, simply plumbed in past the pump? As for filtering, if you can't watch it splash and work and get dirty, what's the fun? lol. I do want to figure out what this model has, but I'll lose interest in 3 loads if I don't get to watch it splash and get dirty hands emptying it!
#9----DA Agitator----you got a PN? I will for sure be searching for that!
Mickey---I will definitely check out the suds behavior and report back exact findings-I bet you got it right.
Gordon--you said in the original CL thread that the timer still has the extra rinse. Check out the big OFF section at the end of Normal. Is it likley in that section, and I need to find the exact unused contacts on the timer and put a switch on the back of the console?
If I don't stop, I'll ask too many questions before it's even indoors. G'night
I've seen that "engine" reference there on several parts that have nothing to do with an engine ... it's apparently a glitch in the database.
Interestingly, the lint filter shows to still be available.  I've not seen that style but it apparently mounts to side of the outer tub, where the side-check valve would ordinarily be fitted.
Detergent Dispenser
I had the detergent dispenser from my mom's machine and sent it to a guy somewhere in New England who I never see here anymore or I'd remember his name.  He had set his machine aside as a future project but I never heard from him or saw any posts about it.  That was probably five years ago.  So there's one out there somewhere.
It's a triangular shaped white plastic/resin assembly that hangs off of the block at left rear.  The detergent trough is suspended over the tub and is contoured at the rear to clear/conform to the curve of the tub opening.  The bottom flap of the trough is spring loaded.  A rod pops out of the hanger block when activated by the solenoid, and triggers the bottom of the dispenser to flip 270 degrees, allowing the powder to drop into the tub the moment the Normal wash cycle agitation begins.
When "Soak & Wash" is selected, it provides an automatic sequence that begins with the Soak cycle, proceeds into the Pre-Wash cycle, then continues into the Normal cycle with detergent drop.   I think an Extra Rinse is called for when using this feature.  The Pre-Wash doesn't rinse, so you're adding even more detergent to the already soapy clothing via the dispenser.  Then again, Kenmores provided those nice spray rinses during both spins, so you could possibly get away without an extra one.
As I recall, there were also small white dots on the timer dial that marked settings for things like "Spin Only" on the Normal and perhaps Delicate cycles, which didn't have them clearly marked the way Permanent Press does.  I can't tell from the pictures if they continued with those markers on the '75 models.
I think my mom's machine was originally outfitted with a "magic filter," which looked a lot different from the one pictured above.  Due to its flexing, it developed a leak and the replacement part was the new style.  It never had to be replaced again.
Others have said so, but I knew and used virtually this same machine over the course of 25 years, was always impressed with its functionality and quiet operation, and consider it a fine Kenmore specimen for its period.
