My SQ ST ran pretty well for about 3.5 years, then last fall I had to get a big channel locks on the pump shaft to unseize it if it sat more than 2 or 3 days. Finally it wouldn't budge and so the motor would overheat and kick off. With 4 other washers hooked up and running, I just moved it aside until today. I've now removed the pump and look at what happened as it sat for 6 months, maybe 9 months. The pot metal crap just deteriorated so horribly that it let the tension of the belt pull the shaft crazy right thru the entire cheap assembly!!
Link is to the first ever post I did on this machine, next entry will also link to the second thread.
www.automaticwasher.org
Late Hanukkah present, Speed Queen Solid Tub
I pick it up tomorrow! The seller says it works, the mismatched dryer died and she convinced her husband to buy a matched set. It looks relatively BOL, the color doesn't concern me at all, 2 cycles and one temp knob.
