Miele W1 WXR 860 WCS Frustrations
hippo
Sep 23, 2021
52
Oregon
I recently purchased a new Miele WXR 860 WCS as an upgrade from another Miele, the WWB 020 WCS. I liked the WWB 020 WCS's wash performance so much that I decided that I wanted the newest top-of-the-line machine. The WXR 860 WCS’s M Touch color display and promise of customizability were especially appealing, particularly as the WWB 020 WCS's primary downside was limited cycle options . However, I have sadly been disappointed in a number of areas with this new machine, nearly all of which seem to be related to software design.
1. The Miele app is almost completely useless. It doesn’t correctly show what phase of the cycle the machine is in, you can’t see percentage levels of TwinDos, and it frequently refuses to connect to the machine. You also can’t delete the “Demo” machine.
2. Some options, specifically Water Plus, are only selectable from the app. This makes no sense given that the machine has a full color touch display. I would very much like to use this setting from time to time but with the app being near useless it is impractical.
3. The machine displays frequent messages which are slow to close and cannot be turned off. For example whenever the Prewash option is selected a message very slowly scrolls down from the top of the screen instructing to put 1/3 of the detergent in the prewash compartment and 2/3 in the main wash compartment. I wash with prewash often and it is very annoying to have to wait to dismiss this slow notification each time I run the cycle, even if the prewash was saved in a Favorites program. The same issue is present for Stains options. Selecting most Stains options results in a “Tip” slowly scrolling from the top of the screen and you have to wait until it has scrolled all the way down to dismiss it. The cumulative effect of these notifications borders on absurd. For example, when I’m washing a particularly heavily soiled load and select Prewash, Grease Stains, and Sand/Soil I have to dismiss at least 3 messages just to run the program. There are other annoying messages as well, especially for Softsteam and Singlewash options. Perhaps the worst of all is that if Remote Control is enabled then EVERY time a program is started, even from the machine’s display, a message appears that “Machine can be remotely controlled” which again must be dismissed. This is so annoying that I have completely disabled the remote control feature which not only removes that functionality but prevents me from accessing Water Plus. The ability to completely disable all of these messages or at least to be able to dismiss them much more quickly (no scrolling animation) would make using the machine far more pleasant.
4. Unless TwinDos is used for a cycle Light, Normal, and Heavy soiling cannot be selected. This is not at all clear in the manual and is detrimental to being able to configure the machine for proper washing. While I often use TwinDos I also have need for specialty detergents, especially for very delicate items and for very heavily soiled work clothes with machine grease on them. TwinDos is not suitable for either purpose but I cannot select soiling level with manual dosing. This is especially problematic for the heavily soiled items where I cannot choose the Heavy Soil option while using the necessary speciality grease-cutting detergent. This issue is compounded by the choice to not allow refillable TwinDos containers and programmable detergent options in the US market which is very consumer-unfriendly.
5. Actual EcoFeedBack is not available. Page 17 of the manual states "You can view the actual amount of energy and water used by a program both during and at the end of the program… You can view the consumption data for the last wash program and for total consumption (see “Settings – Consumption”).” This is not actually possible and the machine only displays an estimate before the program starts.
6. The manual states that AllergyWash is available to select with the Normal cycle, however this is not possible on the machine.
7. The machine is excessively sensitive to imbalance. The machine is perfectly leveled and often spins without vibration. However, it seems to be programmed to be so sensitive to imbalance that most programs are extended by 10-20 minutes while the machine attempts to rebalance. This was never a problem with the WWB 020 WCS washing identical loads.
8. QuickIntenseWash takes much longer than advertised and usually does not conduct the final spin. I believe that this is related to the former issue. QuickIntenseWash usually takes 10-20 minutes longer than advertised and then finishes with completely saturated laundry that has not been spun at all.
9. The drum light will not function during a program. It is disappointing that the drum light cannot be manually activated during a program when it is desired to observe the washing progress.
10. Almost all cycles take longer by default than on the WWB 020 WCS. Normal, Dress Shirts, and Dark Garments now take extended periods of time by default. These seem excessive, I've watched the entire Dress Shirts cycle and its approximately 1 hour length and level of agitation are simply unnecessary for my lightly soiled shirts even with the Gentle option enabled.
11. It is disappointing that only 12 custom programs can be saved. 16 or so would actually cover all my bases but this is a minor frustration compared to the others.
With respect to the balance issues, I do see that there are options in the Programming Mode related to the Imbalance Sensor. The options are:
<ul>
<li>Tacho</li>
<li>Tacho + EZU</li>
<li>Tach + Imbal. sensor</li>
</ul>
I have not changed it from the default "Tacho + EZU" yet and I'm hoping that some forum members can shed light on what the other options mean and if they might be useful in forcing the machine to operate in a timely manner.
Does anybody else share any of my frustrations with this machine? Any tips or workarounds would be wonderful to hear.
I'm very seriously contemplating returning this machine and upgrading to a Little Giant which I understand has much faster cycle times and the ability to program completely custom cycles out of different option blocks. Its 240V electrical requirement is the main impediment to this but I'm not sure I can stick it out with the WXR 860 and all of its frustrations.
I own the WWH860, previous model, but here are a few comments:
1. The 4.0 version of the app is very poor. The previous 3.8 version was better and more usable. Hopefully Miele gets this fixed. If you have an android phone you should be able to find an apk via google to install the previous 3.8 version that is much more functional. IOS users are out of luck due to no sideloading allowed on non-jailbroken phones.
2. Water Plus can be enabled for all programs in settings/service menus.
4. Heavy and Light are there for TwinDOS only and it makes sense. This regulates how much detergent is dispensed from the TwinDOS bottles. When manually dispensing the detergent via the drawer the Heavy and Light TwinDOS settings would not do anything.
6. AllergyWash is a Euro way of saying extra rinse. It is there under extras.
9. The drum light has never been something that could be turned on or off manually. This is nothing new. I understand it would be nice to have, but I can't see faulting the unit for not having the option.
10. Dress shirts is almost an hour on my WWH860 as well. If you add extra rinses, etc. by default then the cycles get longer. I usually use Dress Shirts with the Single Item Wash option. This usually makes it about 38 minutes. I don't think I would want a cycle any shorter than that.
11. I have zero custom cycles. So I don't really feel your pain. lol.
I appreciate your response moon1234.
1. I very much hope they do fix it! It’s be cool if it worked.
2. I did find this in the programming menu. I haven’t expinented to see if it actually affects all cycle or if it just adjusts the extra level when it’s enabled in a Mobilestart cycle. Anyway, I still find it frustrating that it can’t be easily selected for a given cycle. It’s not needed all of the time.
4, Perhaps your machine is different but heavy and light definitely do more on the WXR 860 and my old WWB 020 than just dosing levels. The cycle time and water consumption are changed as well.
6. I figured out that on the WXR 860 AllergyWash does add another rinse. However it also lengthens the wash time somewhat as well. This is a minor concern compared to the others however.
9. I agree with you, this is hardly a fault. It’d just be really neat for laundry enthusiasts to be able to use the hardware, especially since the WXR has a touchscreen button for the light that’s just disabled during the cycle.
10. This answer is very interesting to hear. My WBB 020 is of the same generation as your machine, but the entry level as opposed to top model. I’m learning that the WWB 020 differed quite a lot from its stablemates. It was, for instance, the only machine with a 1400 rpm spin as opposed to 1600 rpm. And the cycle programming seems to have been quite different as well. On the WBB 020 it did dress shirts with three rinses in 0:43 and it was a phenomenal cycle for quickly washing lightly soiled and delicate laundry. I never had any problems with it not cleaning throughly enough. The cycle time on our 860 machines is about what it would have been on my WWB 020 with heavy soil selected. I wonder why Miele programmed them so differently.
Just some quick guesses
In Europe, the Shirts cycle includes steaming by default - maybe your other Miele didn't default to steaming? Same should be true for the Allergy option, which has a steam phase after the main wash (again, in Europe). Just some quick thoughts.
I also wonder what would happen if the machine is set to a different country. Will it still lock the user out of some settings?
Stephen, the manual does indeed make it sound as though you can activate the light at any time. Unfortunately this is only possible when a cycle is NOT running. During the cycle you can swipe down to access the menu and see the light sensor button but touching it does not do anything.
Logixx, The WXR 860 does indeed default to Softsteam in the dress shirts cycle. However, the cycle time I quoted is with Softsteam deactivated, with the default Softsteam option it takes about 1:40.
You can change the language of the machine both in Settings and in Programming Mode. However, there doesn't seem to be an option for region beyond that. I have tried changed the language and it doesn't seem to change any cycle parameters.
Hi Hippo,
After recently acquiring a WWR860. I also share the same frustrations. My business partner purchased the machine. 6 months later bought a property with integrated appliances so I took it off her hands.
For the last 3 years I've had an AEG TOL 9000 series with touchscreen and absolutely love it. This was a great opportunity to try a nearly top of the line Miele machine at hardly any cost.
I've used it daily for the last three months and cannot wait to have the spare time to re-plumb the AEG in.
It's clearly built very well altho the soap dispenser feels very cheap. I like the M-touch control. Very easy to use and flick through various programmes and settings. The updates work really well and within a week of having the washer in use it announced on the app there was an update and most programmes on the machine changed, including an upgrade to Powerwash 2 ( quick power wash duration changed from 59 mins to 49mins)
Unfortunately the cons outweigh the pros:
As you said the excessive sensitivity to imbalance is infuriating. As well as adding up to 20 mins to the wash time I'd say it only spins at 1600 on 70% of wash loads, deciding to reduce to 900-1200 for the remaining. Which means selecting an additional Spin cycle afterwards which almost always reaches 1600 straight away! The machine is perfectly levelled.
It water locks if any load is absorbent and more than half a load, which adds another 10 mins to the cycle.
if you add the short option ( dropping the cottons cycle from 2.55hr to 1.20hr) it only spins once during the rinses. Doesn't matter if you add an extra rinse or not. You could have four rinses but only one spin between them.
If you want to add something to the wash using the 'Add Laundry' option once you close the door and re start the cycle it will empty the drum of wash water and re fill with clean water, thus disposing of the laundry detergent. One user commented it only drops the water level to a safe level to open the door. This is not the case. Once you re start it drains the entire drum until you hear the pump chugging and will then re fill.
Not a fan of the power wash system. My white socks are not coming out as clean as they do in the AEG. It's an interesting system to watch, esp the spins at the start of the cycle but draining the drum of concentrated water with detergent once the clothes are wet so the clothes rotate against the heated drum does not agitate the clothes like a traditional system where the clothes are agitated/bashed against a small amount of water/detergent. The machine also defaults to power wash on a lot of cycles including the cottons programme if the load is not a full load and cannot be over ruled unless you choose a spin cycle of 400RPM or less.
Was very excited to receive this machine and really thought it was going to be an amazing piece of kit and was ready to replace the AEG heat pump with the matching Miele dryer, but the AEG dryer is staying and I can't wait to have the time to re-plumb the AEG 9000 back in.
Feedback
I have an older Miele W1 WMR861WPS and I'm very happy with the machine. Like others, the imbalance system is more sensitive than my older W5965, but I put that down to the larger tub in the same casing. I can be a little annoying, but I'm used to it now.
1. I agree with the new app being useless and don't like any of the 'new' features. They have definitely gone backward here.
3. With the messages coming up, you should be able to swipe the screen up to make it disappear. I have a similar screen on the G7000 dishwasher.
4. This makes sense as it adds more or less detergent depending on the soil level. As you mention, you can adjust the wash parameters by adding a prewash, soak or use the stains option which will lengthen the program.
5. There should be a yellow bar at the top of the display that you should be able to drag down to see the consumption during the program. Again, with my dishwasher, this can be a little difficult to drag the screen down.
6. Yes, normal is the energy program, so they probably lock that feature out. Again the instruction book is not always accurate.
7. Agree, but not a big issue anymore.
8. The length of time could be due to the temperature of the incoming water
9. Not an important point for me.
10. This could be due to load size and incoming water temperature. If you wash 5 shirts, you can enable the 'single wash' option as it's good for up to 1 kg (2.2 lbs) of laundry.
11. I have 10 favourites and it works for me.
led light
I'm equally frustrated by the impossibility to turn the led on during cycles. However, I think they prevent you to do that in order not to kill the led. Led life is very temperature dependant, and they would need to condition led lightning to drum temperature or something to make it safe (for the led that is)...
W1 powerwash2
I don't have any of the issues the OP mentioned nor do I have the top of the line model its now 2 years old and has been used daily, Never an issue with spinning it even does it with towels and bathmats, I can add extra rinse and water levels if required but I trust it to know how much water it needs and it just gets on with it. I have got used to it being different to the W9444 I had before which although both having the 1600 the W1 seems to spin longer at top speed, It does not have WIFI nor TwinDos I did not want either as I use powder for whites and liquid for colours both of which I change at times and did not want to be tethered to Miele products. Have had Tech out 2x as there was a glitch in the program and although it did not drain when you added an item it would skip the majority of the wash cycle and go straight to rinse..... Its sorted now and I don't miss my old one anymore I don't think it will last 10 years but if not I won't buy another I will dig about and find a used one if I have to. The pic is before I plumbed it in.
Austin
Spinning
Really can't agree.
I have a WWF 360 which should have the same tub/drum and it basically always spins at full speed and finishes within time.
Mine can add time after a PowerWash main wash on Cottons if the load is absorbent as it adds another rinse.
Also spins after every rinse with short selected.
If the machine denies full speed final spin it should store an error code in the service menu.
May be helpful to call service and ask if that warrants a technician visit.
<span style="text-decoration: underline;">stevefromsydney</span>, thank you for your response. It's gratifying to know that I'm not the only one frustrated with this machine. I think that the frustration in particular is compounded by the feeling that the machine is so close to greatness because many or most of the issues could be resolved with nothing more than a software change.
I have experimented with changing the "Imbalance Sensor" setting to "Tacho + Imbal sensor" as indicated in my first post. I haven't had the chance to watch the machine enough yet to reach a definitive conclusion but my impression so far is that is has helped. So you may wish to try that.
Another Programming Mode setting you may wish to try is deactivating "Controlled energy cons." I have heard, but not confirmed, that it disables PowerWash completely. Since you don't like the results with PowerWash this might help you. I did change this setting on my machine and noted changed, usually significantly shortened, cycle times. However I have not yet run cycles to test the theory.
I agree with you that the draining of water and detergent in both the PowerWash and Add Laundry features is very odd and seems to be counterproductive, both to washing quality and efficiency. I almost never use Add Laundry so this isn't as important to me but I'd note you can always add a touch of extra detergent directly to the drum along with the additional laundry if you desire.
What exactly do you mean by it "water locks"? I wonder if this is some of my frustration with it extending cycle times.
<span style="text-decoration: underline;">mielerod69</span>, thank you for your detailed notes.
2. Unfortunately swiping to dismiss the messages doesn't work. I tried it after reading your post and you have to wait for the message to scroll all the way down and tap "ok" before it will go away.
5. The yellow bar is present and you can drag it down to find the menu. But there is no actual EcoFeedBack, only the estimate before beginning the program. It never shows actual consumption and no post-cycle feedback is available.
8. Water temperature can indeed have a big impact on cycle times. However, my incoming water is 134F / 57C so shouldn't be an issue here.
10. Interestingly when I changed the setting noted above that supposedly turns off PowerWash the Dress Shirts cycle time dropped to about the same as the WWB 020 which did not feature PowerWash. I'll have to try running the cycle to see what happens.
<span style="text-decoration: underline;">Ivanovitch_k</span>, this is a very interesting idea that I hadn't considered. However I would still think that very few laundry users would engage the light this way on a regular basis, but for enthusiasts it is still quite the disappointment and would certainly be worth a bulb or two to me over time.
<span style="text-decoration: underline;">ozzie908</span>, I appreciate your response and I'm glad to hear that you're enjoying the machine! Interesting to note that both your older machine and my older machine seem to be less sensitive to spinning issues than the latest models.
<span style="text-decoration: underline;">henene4</span>, thank you for your response. Happy that you're not having problems with your machine. I'll check for codes related to spin, thank you for the idea. Does anybody have a code glossary or service manual?
PowerWash 2.0
I forgot to mention that when you select Water plus option it deactivates PowerWash 2.0. I do this when I'm washing whites as I want more water during the main wash. Maybe stevefromsydney should try it and see if it improves the results.
I sent Miele USA customer service an email asking if there were any plans to make EcoFeedBack available as advertised in a software update, any potential fix for the excessive M Touch messages, and if a service call was warranted for the imbalance issues. Here is the response that I got:
<blockquote style="font-family: Helvetica; font-size: 12px; font-weight: normal; text-size-adjust: auto;">
Dear<span class="Apple-converted-space"> Hippo</span>
Thank you for contacting with us and glad to hlep you. As you ask, I will say Convenient and environmentally friendly dispensing, revolutionary economy with every load. Along with this information you get more information please visit<span class="Apple-converted-space"> </span>www.mieleusa.com.
Should you need more information please do  not hesitated to contact us again.
 Regards,
<span style="font-weight: bold;">Kamal H.</span>
Miele Inc. | 9 Independence Way | Princeton NJ 08540 | United States
www.mieleusa.com
</blockquote>
<span style="font-family: serif; font-size: 16px;">I knew their US customer service was bad but this is astonishingly bad. Completely irrelevant to the questions and basically nonsensical...</span>
<span style="font-family: serif; font-size: 16px;">Does anybody know how to contact a competent person at Miele USA?</span>
Hi Hippo,
Sorry you've had no luck with Miele USA email. I'm able to pull the little orange bar down on the screen able the program info whilst the machine is running and it tells me water and electric consumption in realtime. Since the app update it no longer shows on my phone.
Mielerod69 - thanks for the advice re water plus I will try that and see if it makes a difference.
henene4. Any idea if there is a setting or option that has to be selected to enable it to spin between all rinses. Again two loads today, cottons, 40C, short, and extra rinse selected( I also have the permanent extra rinse selected from within service mode) and it spun at 900rpm after the wash, then a rinse, dumps the water, another rinse then spins at 900, then a rinse, dumps the water, fills for final rinse and then final spin. I wouldn't need the permanent extra rinse if it spun between all rinses. I'm also surprised it doesn't spin at a higher speed after wash and during the rinse.
Short option
Hi Steve,
I find it does the same with my model. I have extra rinse and water plus active and find it rinses well. I have adjusted the water plus level to three drops on the menu. I assume the short option is geared for lightly soiled laundry and therefore less detergent would be used. If you use the short option with Minimum Iron, it spins between each rinse and not just a short burst spin.
Thanks Mielerod69,
Nice to know my machine doesn't have a blip in the programming. How strange that on some models it spins after every wash on short and on others it doesn't.
I have now discovered that the machine will not dispense bleach as advertised.
I turned on the “Bleach” function in settings and the cycle times extend but no dispensing of bleach takes place. The bleach remains in the compartment at the end of the cycle. I have rebooted the machine and toggled the setting repeatedly and tried the Normal cycle, the Towels cycle (three times), and the Dress Shirts cycle. None of the tests were in conjunction with TwinDos.
I will try my luck with Miele USA again…
"Where Convenience Meets Performance"
Wow already flaws in new units just rolled out. Miele cannot fix the prewash on prior models, now the bleach dispensing is useless in the new ones. WTF is wrong with Miele? They won't even acknowledge the issues. Total BS. Subject drift is laughable as posted on miele.usa.
