A 20 year old dream turns into reality
swestoyz
Sep 27, 2004
6,599
Cedar Falls, IA
Hi, gang! I wanted to share an update that I've been waiting to post about for almost twenty years now.
When I first joined AW in August 2004, I saw the many impressive collections from the likes of Unimatic1140, Gansky1, Jetcone, Jetaction, etc., and thought to myself - I could do that! From there I dove head first into the hobby, learning as much as I could and went out and found some pretty cool machines.
Some long time members may recall that I bought a house in the fall of 2006, and I had plans to completely restore the basement of that house to include hookups for the dozen or so machines that I had collected up until that point. However, what was a dream then was meant to stay a dream as I gutted and renovated the living space of that house over the course of three years and lived there for 7 years after that, with little to no time left to really do much to the basement.
Fast forward to the fall of 2017. My wife and I were expecting our daughter and we made the decision to look for a new house in the Cedar Valley area. After a short hunt, we found the perfect 1930's craftsman bungalow in downtown Cedar Falls. Not only was the house itself charming, well maintained, and in a wonderful spot in the downtown area, but it also had the perfect basement for a large collection! My daughter Viv was born in the spring of 2018, tying up the majority of my free time for the next few years.
Starting in the fall of 2020, while we all were stuck at home during Covid, I started the long process of renovating the one half of the basement that would be dedicated to the hobby. The first room, the wash studio in the south east corner, was finished in the spring of 2021. The second room, the main laundry room in the south west corner, was started in late 2023 and was finished just this past August. The renovation process consisted of sealing the foundation walls, lots and lots of painting, installing lighting circuits and fixtures, putting down an epoxy coating on the floors, installing a new water main line from the meter to the rest of the house, installing all of the necessary electrical, water supply and drainage, a full restoration of the original swing out windows, and moving in each machine in and ensuring that all leveling legs were adjusted appropriately. I get it, "why would he say anything about leveling machines?", but when you're moving dozens of machines at once, trying to level them all can take a lot out of a guy!
The wash studio has 18 "spots", each spot has a 120v dedicated circuit, along with a dedicated water supply and access to a drain (the majority of the drainage is into a grey system). In the studio I have two vents and two dedicated 240v service lines as well as provisions for gas at each spot. Along with the extra water supplies that I installed in case I wanted to take out the sink, that is 40 individual shut off valves, and hundreds of PEX fittings. You can be sure that I took advantage of Menards 11% off sales.
The main laundry room has 11 "spots". This room is intended to be the permanent laundry room of the house, so I made sure to run permanent circuits for 1 washer and the option for future owners to have either gas or 240v electric. Outside of the permanent installation, this room has four extra spots along the south wall, four spots along the north wall with 4 dedicated 240v circuits and 3 dedicated 120v circuits, with the intention that this space would be used for combinations and condensing dryers. The final spot in the room is in a really odd spot that will feature a bolt down Bendix, with its own dedicated circuits, water supply, and drains.
The main laundry room also featured a bump out within the foundation wall that originally had a sink and a toilet. The original sink was long gone with I bought the house, and I made the executive decision to not put the toilet back but instead to feature the pink '59 Lady Kenmore set there. In theory I could run a hot water line to that spot and install a stack within the grey water drain, if I decide to leave them there. They dryer would be there as a fancy ornament.
Finally, in the other half of the basement is a nice little nook under the porch that was converted into a workshop. It's small but I can fit a machine in the room and perform a full mechanical restoration, without bumping into the walls. I have a nice Steelcase table that is perfect for doing small item work, and a recently procured Craftsman work bench for the more heavy duty tasks. The bench came with the a coveted 1950's Craftsman 05195 vise, which I've already put into use after taking it apart and lubricating all the machined surfaces.
In total, there are 29 machines now in spots where they can be used, and the two idle spots to showcase the Lady Kenmore set. Not all machines are restored to working order - the '53 GE, the '55 Norge, the '71 Lady Kenmore combo, etc. But now that the basement is done I can finally dedicate some time to slow down and actually work through some of the projects that I've been waiting literally decades to start on. And like most projects,there are still a few small things that I'd like to do in each room, with one of them being to find a way to display the many pieces of ephemera and advertising I've collected over the years. Right now I have stuff just sitting along the utility boards, but at some point I'd like to have framed items and a shelf along the upper utility boards to display some of the neat smaller items. For now, it's honestly not perfect but it's good enough for prime time.
My hope is that this post may inspire another budding collector, and ignite the spark to take this wonderful hobby head on, just like some of the original members inspired within me twenty years ago.
Ok - enough of the long talk, let's see the basement!
The wash studio
The majority of the machines in this room are restored and it's also mostly top loader focused. Washers range from the 1950 WO-65 Frigidaire up through the 1969 Hotpoint. Eventually the '61 Whirlpool combo will take the place of the '71 Lady Kenmore.
Yes, things are pretty cramped in this room, but when you have a large collection space becomes a huge commodity, quickly. I did install a wash tub in the south east corner that can be used as a suds-saver tub, so at the moment the Maytag A806S can save it's suds, if needed. Sadly, the '61 clam shell Frigidaire didn't have a good suds valve, so it's been converted to a non-suds saving machine.
The main wash room
This room is right off the stairs down to the basement, making it more convenient for daily laundry duties of the family. Machines on the south wall are the "daily drivers" that my family is free to use. Eventually the Fisher Paykel dryer will get swapped out for the '71 Lady Kenmore, and I'm hoping that I'll be able to round out the collection with a Westinghouse of some variety where the 1985 Maytag A712 is at.
On the north wall the 240v machines are able to finally stretch their legs. The '67 Philco does need some transmission work and the '56 Duo will also need the rear tub back seal replaced. But the Filtrator and the Miele hum along just as nice as can be! I'm hoping that at some point I'll have a Maytag condensing dryer in this line up, too.
In the odd corner we find the 1938 Bendix model B. From the research I've done, this is quite possibly the oldest Bendix that has surfaced. There was one other drop down door Bendix that showed up several years ago with a slightly lower serial number and a white painted door, but it was really rough and I'm not sure what happened to the machine. This is a machine I'm really looking forward to restoring and doing some wash in!
And finally - we can't have a showcase of the basement without some room lights off! Let those panel lights shine!
A big thank you goes out to Robert, Greg, Don, Jon, Steve, John E, John L, and so many others, for your inspiration, insightfulness, and friendships over the last few decades. I wouldn't be where I am in this hobby without the compassion each of you has shared with me and shared with others.
Ben[this post was last edited: 10/15/2024-22:51]
Wow, Ben!  Where do I even begin?!  Let's start with: CONGRATULATIONS!  An amazing achievement.
Looks like you've done a great job with the electrical, plumbing, floor, walls, I could go on....let alone the impressive and varied cross-section of machines.  Every time I look back up at the photos, I see more great details.
Just wait till Viv goes to a friend's house and discovers that they only have one washer and dryer ha ha.
Great job and this is certainly an inspiring thread!
Mark
Congratulations Ben! I’m very happy you’re able to create this for your hobby. Like you this is something I’ve wanted to do for many years. Unfortunately for me we don’t have basements so not only do these cool machines not exist in the dark corner forgotten for someone to find and restore many years later but I also don’t have the ability to have these machines hooked up in a space that is already underneath the house. So like you I’ve spent the years bringing machines home(many at a great expense) in hopes of one day creating what you have. Seeing yours and a few of the others has also inspired me to one day do the same. I hope you have many years of enjoyment from what you created and maybe one day I’ll be able to see it in person.
Absolutely amazing Ben, congratulations!!! I've enjoyed watching your collection grow over the years and you have some of the best machines out there by far. When I was a kid I could only dream of having a beautiful basement like you have filled with extremely rare machines all lined up, plumbed and operating whenever we wish.
Kow-A-Bunga!
What a swell place you have, Ben.  And all of the machines look so happy lined up with their panel lights on - an impressive collection for sure.  Definitely well organized.  I hope you enjoy many hours working on those still needing attention and just using the ones that don't.
And, the winner of the 'Most Beautiful' is...............  the 1958 General Electric Filter-Flo.
lawrence
Thanks for the kind comments, everyone. I really appreciate it.
Mark, Viv getting to experience a normal laundry room is not something that I had thought about. I can't wait to see how that unfolds!
And Sean, yes that is Mabel, Viv's long hair orange tabby. She loves to photobomb.
It dawned on me this morning that I forgot to include some before photos. I love seeing a good transformation when watching people renovate homes on television, so why not see what I was working with before? My wife has always said that I have good vision for houses and rooms, and for this space I knew exactly what it could be the moment I saw it. That, and the straight flight of stairs down to the basement from the at grade back door.
Here's a photo of the house, in the spring after we bought the house. It mostly looks the same today, outside the general maintenance and landscaping that we've done.
