I don't think that's the suds kill
The suds kill function is built into the fill flume, an elegant, angular affair molded out of bakelite although later ones were made out of Lexan. Some of the fill water is diverted through a passage inside the bakelite flume downward directly into the massive outer tub. When Louisville dumbed-down the flume for the perf-tub FF's, the new rubber flume was aimed so some of the water got sprayed into the outer tub. From personal experience, their aim was "hit or miss". Where the fill spray for the solid-tub machines is a strong and healthy straight stream, the fill spray on the perf models is the messy scattered spritz of a syphillitic.
I think it was Tom Stiyer who explained that the pause in the middle of the first spin only was only there for a circuit-workaround for the first spin when the fill sensor fails to detect any more water in the outer tub (because it has been pumped out) it cuts power to the motor. The cam then proceeds to the next timer interval where the motor power lead gets switched to another hot lead. You can see this in the electrical schematics. I'll try to dig one up.
Thanks for the picture of the model number. As I suspected, this was the very first iteration of this 1960 "T"855 model and was most likely manufactured late 1959 (I need to go to my books to figure out the exact date) before GE execs decided to declare 1960 their "Golden Anniversary" year. Later versions of this model featured metallic gold paint on the control panel. Interesting also is the omission of the "OFF" word from the Suds Return selection. If collectible appliances were priced like most other collectibles, this model would be worth a fortune. Thank you for all the pictures and videos of this machine; it is one of my favorites. As I've mentioned in many other posts, we had the BOL model pictured above, the WA-632 with the same turquoise filter pan which I picked out from the used appliance store in 1964. I'm still kicking myself for not taking the filter-pan with me when they sold the house in 1970. I think that was my all-time favorite washer. Look for 1960 Filter-Flo cut sheets in Ephemera soon.
