So, instead of just flushing the water line, use the DivJet with the pulsator on for 30, to heat and wet the tub, then spin for 30 . Yes?
I was thinking of spraying the clothes with the hot water line flush water, but I don't know about pulsating them without any water in the tub Mike, it might cause problems.
Suds Kill Segment:
I have found that if I have filled at least 1/2 of the outer washer cabinet with suds (from the recirculation) when the machine goes into spin, in will whip those suds around and create even more in the outer cabinet. What happens is then once the tub gets up to full speed the suds start pouring from the outer tub back into the spinning wash tub. So a draining the wash tub in two short bursts seems to stop this from happening completely.
Suds Kill Segment:
