Can't you get something like AquaStop for the hoses?
Our Bosch and Siemens dishwasher and washing machine both have AquaStop valves.
Basically, there's a box with the solinoid valves inside it at the end of the hose and a tube which includes the rubber hose and an electric cable to activate the valve.
It means that the rubber hose is connected to an open valve in the washing machine and never experiences the full pressure of having to hold back the water mains pressure.
The high pressure (non-flowing) mains is held back by copper piping only. So, the rubber tubing only ever gets exposed to flowing water, rather than the extreme static pressure of the mains.
It also means when the valve is closed and the machine's not filling, the water is shut off at the tap on the wall, and not several feet away inside the machine itself.
These machines also all incorporate a float switch in the base which activates the drain pump should the machine fail with the valves open and overfill.
