All New Whirlpool Cabrio
I seen it too....while the impellor may seem a bit different than the past, I am curious as to its washing effectiveness of past versions....
outside of one wash cycle with a DeepWash, I don't see this any more than a new face lift on old technology....most likely still doesn't have a sprinkler, or add any more water to the load.....
and what?.....$500.00+++dollars for a machine with a DownyBall!
AND its gonna hold 4 baskets of laundry per load, the old version was barely effective at 1/2 basket!.....
they should to offer a double your money back guarantee that you will love its performance!.....Whirlpool offered a 6 month trial on the Calypso when it came out, love it or return it!....that's how I got mine....
F&P Design?
I hope this machine is based on the Fisher Paykel Smart Drive design!
I haven't gone through the manual yet. Might shed some more light on it...
Malcolm
Observations...
1) No Downey Ball, dispenser in drawer.
2) No SOFTENER button. Must always rinse with softener enabled.
3) Deep Water isn't a cycle, it is a modifier to most cycles.
4) Five Cycle buttons on the left. How To's are modifiers.
5) Steam option, so there is a heater.
6) No hoses included!
7) No Sanitize certification, so Hot must be Warm.
Malcolm
I actually think it's quite amazing. Instead of x cycles, there are 6 selections on what you wash (I think it was mixed, casual, delicate, bulky, sheets&towels and darks) and 6 selections on how to wash it (Normal, Fast, Eco, Delicate, DeepWater and ColdWater wash).
It has a heater, a recirc (some Cabrios have one, I'm pretty sure) and a timed oxy dispenser.
At least on the UI side, it's one step ahead.
Dryer
1) BIG 8.8 cu ft.
2) No Reverse Tumbling.
3) No drying rack.
4) Exhaust length seems shorter than expected.
Malcolm
@mrb627 On point 7
Not sure about that. The NSF certification requires 4 consecutive minutes at a temperature of 160°F I think. No way to reach this without the use of a heater.
Though, on Normal mode, Hot will be Warm, I doubt this is true for all How To's.
And there are only 5 selections. I read the manual earlier this week.
Not a wash action I would like to have.
About the dryer....when did Whirlpool start putting that big bolt in the back of the dryer? And why? Looks like it would snag fabrics with a full load. There is a picture of the dryer in the first link that Malcolm provided. Last picture at the bottom of the page.
I'm not a fan of the impeller style machines, but I do like what they've done to this one. The cycle and option selections remind me of the Kenmore from the POD 10/23/14, where the cycles are named Colors, Special Knits, etc. I'm also glad that the Deep Wash is an option that can be added to almost any cycle, so it gives the consumer a CHOICE to use the low water HE wash, or a more traditional cycle. I wonder if the new design of the wash plate is to give better "blooming" wash action in both low and high water situations.
I do see this as a step in the right direction. I'm glad that while Whirlpool is a large corporation, they are campaigning now to appreciate things like laundry and other chores, rather than trying to cover them up by saying "just push this button and forget it". Rather than saturate the machine with gimmicks and bells and whistles, everything on the control panel is something that will be useful in some form to any user. It also is without the need for WiFi and apps and other watered down features. I'm almost wanting to buy it right now haha.
If you haven't, you should go to their website and watch the video for their Every day, care. campaign. I like the message that they are relaying, especially because of how much I appreciate the work that goes into the things that are sometimes taken for granted.
Interesting Statement
Here is an interesting statement on their main page for this "NEW" technology...
"School administrators have found that students not having clean clothes to wear is a known contributor to truancy."
Is that right?
Malcolm
New WP TL Impeller Washer
It looks like it is the F&P motor direct drive version of the WP Cabrio machine.
While these washers have been out for almost ten years now they have held up no better than the Calypso and certainly are more problematic about balancing and handling big loads than the Calypso. It should have the recirculating water pump system however, all the DD top load washers have had one.
Nozzle
Not sure about the spray nozzle. Expected it the be higher on the bulkhead rather than dead center...
Wonder if there may eventually be a agitator model...
Malcolm
jerrod6
Jerrod6,
For some frontloaders are not a choice i may not like front loaders but for some it easyer using a topload washer right now i may have a frontload washer as a daily driver but the next washer me and my mom will buy will be the hubesch topload zwn432 model with matching dryer and also it depends on space where the washer is install. So far this new whirlpool looks great makes me wonder if they will offer an agitator model as well.
Cabrio Agitator Model?
I don't think you will ever see any new agitator machines introduced, WP had an agitator version of this washer earlier that has been discontinued.
Agitator washing of clothing is just not efficient [unless you reuse the wash water for at least three loads of clothing ], you just can't get users to use the huge quantities of detergents hot water etc needed for good cleaning, and if you do manage to use enough detergent for decent cleaning you use way too much water trying to rinse clothing in a deep rinse washer.
Fortunately for all mankind Agitator full fill washers are fast going the way of the incandescent light bulb.
Metal pin
I'm not sure if I'm right that I assume A440 ment that little pin in the middle back of the drum?
It would be a good place for a temperature sensor. It would not be affected by directed hot air streams or cold laundry.
For a water nozzle the place would not as good as direct hot air is needed to create the vapor.
An electric dryness sensor dosen't make sense as well as it would not have enough laundry contact.
