another cold wash article
Article is behind a paywall, but I don't need a lecture anyway so I'm good.
From the blurb I was able to read, sounds like some preachy person trying to tell us why her way of doing laundry is the way every one of us should be doing things because one way works for everybody. Ugh.
I read it, there are ways about some kinds of paywalls.  It's the usual cold water promotion, with a some additions such as also being anti-machine drying on point of both energy usage and causing deterioration of clothing and spewing lint (both natural fibers and synthetic fiber pollution) into the environment.
I did two loads tonight Cold weather indoor garments washed with a "warm" water temperature of that started out at 96 degrees F and cooled down to 89 degrees F by the end of the wash. Kitchen hand towels that started out at 116 degrees F and ended up at 138 degrees F by the end of the wash phaase. Sunday I did a huge load of towels that when the wash phase finished, the temmperature was 148 degrees F. Flannel sheets wasshed at 92 degrees F.
More Hokum from someone who does not have enough to do
In Elena Karpova’s household, the rumbling sound of a clothes dryer has become an unfamiliar noise.
“I use the dryer maybe twice, three times a year, just when it’s an emergency,” says Karpova, a professor at the University of North Carolina at Greensboro who studies textile and apparel sustainability.
Instead, Karpova prefers to air dry her clothes. Dryers, she says, are “energy gobblers” and when combined with machine washing too often can wear out clothes much more quickly, in addition to having huge environmental and climate impacts.
Washing “can be the most significant thing that you do” to your clothes, says Mark Sumner, a lecturer focusing on sustainability within the textile, clothing and fashion industry at the University of Leeds’ School of Design. Laundering a garment could cause it to shrink, become misshapen, fade or pill (when small balls of fuzz form on the surface of clothes).
“It can be really quite harmful to the clothes itself,” shortening the life of the garment and leading to purchases of new clothing, Sumner says. “And of course, let’s not forget about energy and water and detergents used in the washing process,” which can also release microfibers into waterways and exacerbate the problem of microplastic pollution. “It’s a double whammy.”
Making simple changes to your laundry routine, he and other experts say, can go a long way in helping you reduce emissions, save money and take better care of your clothes.
Understand the impact
While many people focus on manufacturing when calculating their clothes’ environmental impact, machine washing and drying clothes can often be a major source of pollution and emissions.
In fact, the impacts of laundry can be “on the same order of magnitude” as the production phase of clothing, says Roland Geyer, a life cycle assessment expert and professor at the Bren School of Environmental Science and Management at the University of California at Santa Barbara.
“People are washing their clothes more frequently than they ever did before,” Sumner says. According to Energy Star, the average American family does 300 loads of laundry each year.
A standard washing machine uses around 20 gallons of water for each load and electric dryers, on average, can use anywhere from 1,800 to 5,000 watts of energy, or about 1.8 to 5 kilowatt hours of electricity per cycle, according to Energy Star.
Choosing more efficient washers and dryers can make a difference for the planet and your wallet. Energy Star certified washing machines generally use about 25 percent less energy and 33 percent less water than regular models. Meanwhile, certified dryers are 20 percent more efficient compared to standard dryers.
A household that uses washers and dryers certified by Energy Star could reduce their carbon footprint by more than 400 pounds of CO2 annually, according to the Environmental Protection Agency, which is equal to planting a quarter acre of trees.
If every American household swapped out their appliances for more efficient models, the impacts would be even greater. The combined cost savings would swell above $4.8 billion each year and more than 41 billion pounds of annual greenhouse gas emissions would be prevented from entering the atmosphere, the EPA estimates. That’s equivalent to the emissions from nearly 4 million cars.
Tips to make laundry day more gentle on the environment
But even if you have high-efficiency machines, experts say it’s still important to cut down on the loads of laundry you’re doing.
“Every time we put that garment in the washing machine, part of it is gone down the drain,” says Cosette Joyner Martinez, an associate professor in the department of design, housing and merchandising at Oklahoma State University. “Then we lose another piece of it in the dryer in the lint trap, so we’re disintegrating our garments.”
Know what needs washing and when
Aside from noticeable odors or visible stains, when your clothes need to be laundered largely depends on how the garments are worn and the type of material. Clothes that you exercise and sweat in, for instance, should be washed more frequently than the outfit you wear to work a desk job.
“Lots of people just have a T-shirt worn once and then they put in the laundry basket without thinking whether it’s clean or not,” Karpova says. “People don’t think about, ‘Is it clean? Does it need to be laundered?’ It’s just you go through the motions.”
What your clothes are made out of also determines how long you can go between washes, experts say.
Natural fibers like wool or cotton typically need to be washed less than synthetic materials, such as polyester. While polyester works well for activewear because of its moisture wicking properties, the material is “oleophilic,” or oil-loving, attracting oil from skin that can contribute to body odor. To make matters worse, research has shown that sweaty-smelling compounds can cling to polyester fibers and not wash out completely, leading to a buildup of odors over time.
The chemical structure and “fiber morphology” of natural fabrics are very different from synthetics, says Preeti Arya, an assistant professor of textile development and marketing at the Fashion Institute of Technology in New York. Wool, for example, is naturally odor resistant. The fibers can absorb large amounts of moisture which helps to keep skin drier, and prevent the sweat and bacteria that cause body odor from collecting. Wool fibers also have another unique property: The ability to trap odor molecules and only release them when laundered.
Odorous compounds, perspiration and oil are locked away in the center of wool fibers, Arya says. Even if you’ve been sweating, you likely won’t see sweat stains or smell.
On the other hand, she says, if you wear polyester for a few hours, “You have to wash it because polyester loves our body oils and odors.”
How you wash matters
Water heating consumes about 90 percent of the energy it takes to operate a washing machine, according to Energy Star. Changing your washer’s temperature setting from hot to warm can cut energy use in half. Washing with cold water can reduce your energy footprint even more. By washing four out of five loads of laundry in cold water, you could cut 864 pounds of CO2 emissions in a year, an amount equivalent to planting 0.37 acres of U.S. forest, according to the American Cleaning Institute.
Experts encourage using the cold cycle as much as possible. “The temperature that we’re washing with is often way too warm,” Joyner Martinez says, adding that hot water settings are only really necessary for sanitizing. Modern laundry detergents, even those that aren’t marked for cold-water use, are typically formulated to clean just as well at lower temperatures. While single-dose detergent pods have become increasingly popular, a debate is raging over whether they may contribute to the growing plastic pollution problem that threatens human health and the environment.
Does the film around detergent pods really biodegrade? A debate is raging.
Keep in mind that washers use about the same amount of energy regardless of the size of the load, so try to only run your machine when it’s full. And consider using higher spin settings if your washing machine has the option, which can reduce drying time.
Some experts also caution against dry cleaning too often. In addition to the energy needed to power dry cleaners, traditional operations often use polluting chemicals that can harm human health and the environment. Some research also indicates that the chemicals can stay on dry cleaned clothes.
In January, the Environmental Protection Agency added 1-bromopropane, a powerful dry-cleaning solvent and airborne pollutant that has been linked to cancer and neurological damage, to its list of hazardous air pollutants — a designation that allows the agency to limit its emissions.
For the first time in over 30 years, the EPA adds to its list of hazardous air pollutants
Certain clothes, such as those with heavy beading or embellishment, require dry cleaning. But some of the delicate materials that you might send to the cleaners such as silk or wool can be gently washed by hand, says Katrina Caspelich, who directs marketing and partnerships for Remake, a global nonprofit organization advocating for fair pay and climate justice in the clothing industry. Test a small section of your garment to make sure it’s suitable for hand-washing — any color bleeding, warping or shrinkage is a bad sign — and use cold water and mild soap.
If you do need to dry clean something, you can ask for more environmentally friendly cleaning options, Caspelich adds. Some cleaners offer professional wet cleaning, where clothes are laundered in computer-controlled washers and dryers that gently clean. Another option is liquid carbon dioxide cleaning, which uses pressurized CO2 in combination with other cleaning agents.
Do you really need to dry-clean that?
You also don’t always need water and energy guzzling machines and detergent to keep your clothes fresh. “Really what people are trying to do when they launder is to make [their clothes] smell good,” Joyner Martinez says.
If possible, Sumner recommends hanging clothes outside in the sun where they can be exposed to UV rays. Steam is another way to de-wrinkle and help refresh your garments. Hang up your clothes in the bathroom while you’re showering or use an at-home steamer.
Air dry more
Whenever possible, choose to air dry your clothes, experts say. “If you’re air drying, that’s saving the most energy,” says Joe Vukovich, a staff attorney at the Natural Resources Defense Council who works on energy efficiency.
If you are using a dryer, make sure to regularly clean the lint screen, dryer duct and moisture sensors to maintain efficiency. Instead of using timed drying, choose the automatic cycle, which uses moisture sensors to determine when your clothes are dry and reduces the chance of running the machine for longer than needed. You can also dry loads of laundry back-to-back and make use of residual heat.
Newer dryer models also often use less energy to dry typical loads on low heat than on high heat, even though it may take longer to dry clothes, according to the American Council for an Energy-Efficient Economy.
But if you want to increase your clothes’ life span, experts recommend avoiding the dryer. Air drying clothes that need to be washed more frequently, such as workout gear, can make a “huge difference,” Joyner Martinez says. “The life extension that we get in the product is very dramatic.”
It’s not really worth paying for a falsely written article about people who have done “studies” about pollution from clothes washing and drying.
QSD-DAN in reply #48 has more useful information than that bogus article. I am sure once I get the customized Maytag dryer all together along with the matching A806 washer, my clothes will last a LONG time since I will have the ability to do a gentle wash with fast spin for lightly soiled laundry and a dryer that only has a low heat selection available.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?29578
