christfr
i love this baby shes got her used 20 years ago and has been a tank the whole time i have had it in the house. started it today, took the dog for a long walk came back it was on dry so when that finished i opened it up to unload and it had not drained. so ran a cancle and drain still didnt drain. ran a rinse and hold it wasnt pumping the water to wash. so got all the water out and took the pump apart to see if it had clogged. well oh no when i got down to the food grinder it was just flopping around. took the machine out of the kitchen into the garage and could see that the shaft from the motor that the grinder and impeller attach to had corroded through and snapped off. so i had a newer version kitchen aid in the garage that i got for free 2 years ago. i had left that machine just sit thinking maybe one day i could use parts off it. well took the motor and pump assy out of that machine and put it into the superba. everything fit and the wiring was the same. ran it in the garage and no leaks. so back into the house she went installed and tested it and so far its all good.
