Back Up North to Durham a Year later for a Repair Weekend !!
chestermikeuk
May 29, 2001
7,410
Rainhill *Home of the RailwayTrials* Merseyside,UK
Time flies so quickly and another grand visit to the Northern area of our country, Consett, County Durham visiting Richard (Ricky5050) where we spent a weekend in the sunshine (unlike last time in the rain, see thread) fixing up new / old washers and sorting out what needs to be done....
Beautiful Summer Morning among the fields and meadows.
The gang ready for action...Al (Vacbear58), Steve (SESteve) Mikey, (MikeyMatic) Richard (Ricky5050), Mike (ChesterMikeUK) and Gary on his first visit having trained as a Hoover engineer in the 80`s. Darren (SlowSpin66) is behind the camera..
The mission is to re-wire the timer so it doesn't agitate and do a water mix on the mixed temperature fill on certain programmes, so with wiring diagrams enlarged its a snip, clip and re-wire jobby...the result will be a static fill and less wear n tear on clothes like the original top loaders did.
Mikey (MikeyMatic) gets stuck into a once over on Richards (Ricky505) latest acquisition a Hoover MicroElectronic computer control washer from 1986, Hoovers first computer control washer, needs a new door boot and check up as well as a good clean..
I get to grips on looking at the Hoover Keymatic timer which has the same fault as a few of our members in that a resistor burns out (well it is original from 1961) so not allowing the timed portion of the cycle to proceed ie the fill heat works but the timed 4 or 8 mins wont... we now identify that Richards timer is the 2nd upgrade for this the model the AT model original was AU model ) which still has the larger timer, a clear Perspex moulded cover which is riveted to the timer and is a 36 impulse sequence timer as opposed to the later upgrade with 42 impulse sequences.
Steve has finished the upgrade to the Hotpoint toploader and Richards sorts the laundry for a test wash...and we test out the latest "Persil Bio PowerGems" detergent from Unilever UK....Richard had used them in the new Bosch with some of the gems sticking in the door boot with not enough flushing water action !!
