Reply number 41 stripped motor shaft repair
Hi Glenn, it looks like we posted it almost the same time that looks like a pretty clever repair that might have a chance of working for a good while, if I were going to install a coupler this way, I would also make sure everything‘s very clean and use it very high strength epoxy to keep it from moving slightly and starting to wear and strip out or otherwise work loose.
I don’t know if there’s enough demand for this repair, but as I mentioned in my thread, if someone came up with a steel one, it could be welded to the shaft, you could also make a steel one clamp securely to the motor by drilling a hole through the shaft as your fix Showed. Either way there’s many ways to keep these durable machines running.
John
